Hi !
I have one string array named sensorCommand.
String sensorCommand = 0xEF + 0x01 + 0xFF + 0xFF + 0xFF + 0xFF + 0x01 + 0x00 + 0x07 + 0x13 + 0x00 + 0x00 + 0x00 + 0x00 + 0x00 + 0x1B ;
How can i serial print these values ?
Need Help.
Hi !
Need Help.
Actually, that line will not compile.
If anything, you have String array named sensorCommand.
string != String
If you feel that your really must use Strings (why ?) then the String class has a substring() method. That and a for loop will allow you to print each character of the String or several at a time if you want to.
