system
April 3, 2012, 7:52pm
1
Hello everybody,
i wrote a Programm with Bluetooth-Communication. Everythings good, but at the beginning of the Programm I want to Print some short instructions for further users.
When I open that in PUTTY the Serial.println will not ne shown.
Serial.println("Hello");
Serial.println("Instruction 1");
Serial.println("Instruction 2");
{ // somethings here
Any Idea how I can made these Strings visible?
Greetings
TK
That should work if the USB cable is connected, the Putty is set to the Serial port that the USB driver creates, and at 9600 baud.
system
April 4, 2012, 5:21am
3
Yes, but I want to control it via Bluetooth .
It seems, that the 3 strings are getting lost somewhere. But why? And how can I fix it?
system
April 4, 2012, 5:34am
4
Those 3 strings are being sent via the usb port.
I presume you have bluetooth setup eg if your bluetooth serial line is connected to pins 2 and 3 (or whatever) (send/recv)
mySerial(2, 3); //send/recv (SoftSerial any kind)
//setup
MySerial.begin(9600); //blueooth
//loop
if (mySerial.available())
c = (char)mySerial.read();
mySerial.print(c);
etc etc.
system
April 4, 2012, 5:35am
5
mySerial.println("This will be sent to bluetooth....");
Use SoftSerial or the new library, both work good, i've had issues sending AT commands but i'm sure i'll work it out, default is 9600bps.
