How to Serial.print unsigned char xxxx[] ?
In my sketch I have this that stores serial numbers;
unsigned char login[][8] =
{0x12, 0x22, 0x71, 0x16, 0x13, 0x74, 0x00, 0x00},
{0x10, 0x42, 0x71, 0x11, 0x15, 0x36, 0x00, 0x00},
How do I Serial.print (login[i]) each serial number to the console?
so it would print it as either
or
1222711613740000
with two nested for loops.
try something like this
unsigned char login[][8] = {
  for (int i = 0; i < sizeof login / sizeof * login; i++) {
    Serial.print("login["); Serial.print(i); Serial.print("] = {");
    for (int j = 0; j < sizeof login[0] / sizeof * login[0]; j++) {
      Serial.print("0x");  // Print the "0x" prefix
      if (login[i][j] < 0x10) Serial.write('0');
      Serial.print(login[i][j], HEX);
      if (j < 7) Serial.write(", ");
    Serial.println("}");  // Print a newline after each serial number
void loop() {}
you should see in the serial monitor (set at 115200 bauds)
login[0] = {0x12, 0x22, 0x71, 0x16, 0x13, 0x74, 0x00, 0x00}
login[1] = {0x10, 0x42, 0x71, 0x11, 0x15, 0x36, 0x00, 0x00}
void disp (
    unsigned char *buf,
    int            nByte )
    char s[10];
    sprintf (s, "0x%02x", buf [0]);
    Serial.print (s);
    for (int n = 1; n < nByte; n++) {
        sprintf (s, ", 0x%02x", buf [n]);
        Serial.print (s);
    Serial.println (s);
void
setup (void)
    Serial.begin (9600);
    disp (&login [1][0], 8);
    disp (&login [0][0], 8);
void loop (void) { }
Thank you both for your help, that's fantastic.
