No problem man.
GPS Level Convertor Board Test Script
03/05/2012 2E0UPU
This example connects the GPS via Software Serial.
Initialise the GPS Module in Flight Mode and then echo's out the NMEA Data to the Arduinos onboard Serial port.
This example code is in the public domain.
Additional Code by J Coxon (http://ukhas.org.uk/guides:falcom_fsa03)
COLLEAGAMENTI
arduino ---------- GPS
GND,VCC GND,VCC
D10 RX
D9 TX
!!!!!!!!! PIN ENABLE GPS collegato a VCC (5V) !!!!!!!!!!
COLLEAGAMENTI
arduino mega ---------- GPS
GND,VCC GND,VCC
TX1 RX
RX1 TX
TX2 TX SerialToUSB
byte gps_set_sucess = 0 ;
String GNGGA = String();
String PUBX = String();
String GNGGAtoSend = String();
//pinMode(2,OUTPUT);
//digitalWrite(2,LOW);
Serial1.begin(9600);
// START OUR SERIAL DEBUG PORT
Serial2.begin(9600);
Serial2.println("Serial1 Level Convertor Board Test Script");
Serial2.println("03/06/2012 2E0UPU");
Serial2.println("Initialising....");
// THE FOLLOWING COMMAND SWITCHES MODULE TO 4800 BAUD
// THEN SWITCHES THE SOFTWARE SERIAL TO 4,800 BAUD
Serial1.print("$PUBX,41,1,0007,0003,4800,0*13\r\n");
Serial1.begin(4800);
Serial1.flush();
// THIS COMMAND SETS FLIGHT MODE AND CONFIRMS IT
Serial2.println("Setting uBlox nav mode: ");
uint8_t setNav[] = {
0xB5, 0x62, 0x06, 0x24, 0x24, 0x00, 0xFF, 0xFF, 0x06, 0x03, 0x00, 0x00, 0x00, 0x00, 0x10, 0x27, 0x00, 0x00,
0x05, 0x00, 0xFA, 0x00, 0xFA, 0x00, 0x64, 0x00, 0x2C, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x16, 0xDC }; //44byte
while(!gps_set_sucess)
sendUBX(setNav, sizeof(setNav)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setNav);
gps_set_sucess=0;
// THE FOLLOWING COMMANDS DO WHAT THE $PUBX ONES DO BUT WITH CONFIRMATION
// UNCOMMENT AS NEEDED
Serial2.println("Switching off NMEA GLL: ");
uint8_t setGLL[] = {
0xB5, 0x62, 0x06, 0x01, 0x08, 0x00, 0xF0, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x01, 0x2B}; //16byte
sendUBX(setGLL, sizeof(setGLL)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setGLL);
gps_set_sucess=0;
Serial2.println("Switching off NMEA GSA: ");
uint8_t setGSA[] = {
0xB5, 0x62, 0x06, 0x01, 0x08, 0x00, 0xF0, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x02, 0x32}; //16byte
sendUBX(setGSA, sizeof(setGSA)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setGSA);
gps_set_sucess=0;
Serial2.println("Switching off NMEA GSV: ");
uint8_t setGSV[] = {
0xB5, 0x62, 0x06, 0x01, 0x08, 0x00, 0xF0, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x03, 0x39}; //16byte
sendUBX(setGSV, sizeof(setGSV)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setGSV);
gps_set_sucess=0;
Serial2.print("Switching off NMEA RMC: ");
uint8_t setRMC[] = {
0xB5, 0x62, 0x06, 0x01, 0x08, 0x00, 0xF0, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x04, 0x40}; //16byte
sendUBX(setRMC, sizeof(setRMC)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setRMC);
gps_set_sucess=0;
Serial2.print("Switching off NMEA VTG: ");
uint8_t setVTG[] = {
0xB5, 0x62, 0x06, 0x01, 0x08, 0x00, 0xF0, 0x05, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x46}; //16byte
sendUBX(setVTG, sizeof(setRMC)/sizeof(uint8_t));
gps_set_sucess=getUBX_ACK(setVTG);
readPUBX_GNGGA();
findUBloxToSend();
//Serial2.println(findStr(PUBX,5,6));
void findUBloxToSend(){
char* appoggio;
GNGGAtoSend = findStr(GNGGA,1,2);
GNGGAtoSend[GNGGAtoSend.length() - 1] = ;
/*GNGGAtoSend += findStr(GNGGA,2,3);
GNGGAtoSend[GNGGAtoSend.length() - 1] = 0;
GNGGAtoSend += findStr(GNGGA,4,5);
GNGGAtoSend += findStr(GNGGA,6,7);
GNGGAtoSend += findStr(GNGGA,7,8);
GNGGAtoSend += findStr(GNGGA,9,10);
GNGGAtoSend += findStr(PUBX,13,14);
//GNGGAtoSend.trim();*/
Serial2.println(GNGGAtoSend);
Serial2.println();
void readPUBX_GNGGA(){
while(!Serial1.available());
while(Serial1.available())
Serial1.readStringUntil('
Serial1.readStringUntil(‘A’);
GNGGA = Serial1.readStringUntil(’’);
Serial1.println("$PUBX,0033");
Serial1.readStringUntil(’$PUBX’);
PUBX = Serial1.readStringUntil(’*’);
Serial2.print("GNGGA : ");
Serial2.println(GNGGA);
Serial2.print("PUBX : ");
Serial2.println(PUBX);
Serial2.println();
String findStr(String str, int virgolaIn, int virgolaFin)
int a = 0;
int virgole = 0;
int inizio = 0;
boolean controllo = true;
while(virgole < virgolaFin)
if (str[a] == ‘,’)
virgole = virgole + 1;
if (controllo == true)
if (virgole == virgolaIn)
inizio = a;
controllo = false;
a = a+1;
//Serial2.println(virgole);
//Serial2.println(inizio);
//Serial2.println(a);
return str.substring(inizio,a);
/* int a = 0, virgole = 0, inizio = 0;
while(virgole < 14)
if (PUBX[a] == ‘,’)
virgole++;
if (controllo)
if (virgole == 13)
inizio = a;
controllo = false;
a++;
String velVert = String(); //globale
velVert = PUBX.substring(inizio,a);
Serial2.println(velVert);*/
// Send a byte array of UBX protocol to the GPS
void sendUBX(uint8_t *MSG, uint8_t len) {
for(int i=0; i<len; i++) {
Serial1.write(MSG[i]);
Serial2.print(MSG[i], HEX);
Serial1.println();
// Calculate expected UBX ACK packet and parse UBX response from GPS
boolean getUBX_ACK(uint8_t *MSG) {
uint8_t b;
uint8_t ackByteID = 0;
uint8_t ackPacket[10];
unsigned long startTime = millis();
Serial2.print(" * Reading ACK response: ");
// Construct the expected ACK packet
ackPacket[0] = 0xB5; // header
ackPacket[1] = 0x62; // header
ackPacket[2] = 0x05; // class
ackPacket[3] = 0x01; // id
ackPacket[4] = 0x02; // length
ackPacket[5] = 0x00;
ackPacket[6] = MSG[2]; // ACK class
ackPacket[7] = MSG[3]; // ACK id
ackPacket[8] = 0; // CK_A
ackPacket[9] = 0; // CK_B
// Calculate the checksums
for (uint8_t i=2; i<8; i++) {
ackPacket[8] = ackPacket[8] + ackPacket[i];
ackPacket[9] = ackPacket[9] + ackPacket[8];
while (1) {
// Test for success
if (ackByteID > 9) {
// All packets in order!
Serial2.println(" (SUCCESS!)");
return true;
// Timeout if no valid response in 3 seconds
if (millis() - startTime > 3000) {
Serial2.println(" (FAILED!)");
return false;
// Make sure data is available to read
if (Serial1.available()) {
b = Serial1.read();
// Check that bytes arrive in sequence as per expected ACK packet
if (b == ackPacket[ackByteID]) {
ackByteID++;
Serial2.print(b, HEX);
else {
ackByteID = 0; // Reset and look again, invalid order
