I'm still trying to figure out Arduino code the only coding language I know really well is python
here's my code pasted into the foroms directly
#include <SD.h>
int chipSelect = 4;
char bdaylist[2][6][13];// this use to be bdaylist[50][6][13] buy with strncpy i had to chaenge it
File file;
pinMode(chipSelect, OUTPUT);
while(true){
if (SD.begin(chipSelect)){
Serial.println("SD Card initialize.");
}else{
Serial.println("Could not initialize SD Card.");
if(SD.exists("bdays.txt")){
Serial.println("card contanse the birthday list");
file = SD.open("bdays.txt", FILE_READ);
char character;
char charBuf[13];
String word;
int row = 0;
int col = 0;
while ((character = file.read()) != -1){
if(character == '|'){
Serial.print("word = ");
Serial.println(word);
word.toCharArray(charBuf, 13);
Serial.print("charBuf = ");
Serial.println(charBuf);
word = "";
Serial.print("bdaylist[");
Serial.print(row);
Serial.print("][");
Serial.print(col);
Serial.print("] = ");
//strcpy(&bdaylist[0][1], charBuf, sizeof(charBuf));
strncpy(bdaylist[row][col], charBuf, sizeof(charBuf));
Serial.println(bdaylist[row][col]);
col++;
else if(character == '\n'){
word = "";
Serial.print(row);
Serial.print("][");
Serial.print(col);
Serial.print(bdaylist[row][col]);
//Serial.println();
row++;
}else{
word = word+character;
//Serial.println();
file.close();
Serial.println("--reading ended--");
for(int r=0;r<2;r++){
for(int c=0;c<6;c++){
Serial.print("<");
Serial.print(bdaylist[r][c]);
Serial.print(">\t");
Serial.println("--end--");
strcpy doesn’t take 3 arguments
Don’t use the size with strcpy
Basically you want to use this strlcpy which is safer than strcpy and strncpy
size_t strlcpy( char *dst,
const char *src,
size_t size );
See https://www.qnx.com/developers/docs/7.1/#com.qnx.doc.neutrino.lib_ref/topic/s/strlcat.html for important notes
So you need the pointer to somewhere in memory where you have enough bytes to copy your charbuf content including the trailing null.
If you need a 2D array containing the texts, then indeed you need to define a 3D array, the last dimension being for the bytes of the data
const size_t nbCols = 30;
const size_t nbRows = 10;
const size_t maxTextLength = 12;
char storage[nbRows][nbCols][maxTextLength+1]; // +1 for the trailing null char
Note that this array uses up 30x10x12 bytes that is 3600 bytes. Depending on your arduino it’s a lot, It won’t fit on a UNO for example.
The destination pointer to the memory location where you have the bytes available can be given by the first part of the array, for example
storage[3][5]
Or by taking the address or the first byte
&(storage[3][5][0])
This would be the address of 4th row and 7th column (indexes start at 0).
And if you use strlcpy() then the size at that location is maxTextLength+1
To fill up the charbuf array you have only maxTextLength bytes available and you keep the +1 byte always for the trailing null if your text reaches max capacity
I figured it out I am reading only one line of the text file on the SD card instead of storing it into a 3d array thanks for the help.
this forum is solved no need to post anymore. thank you all. good bye.
