I am using the simple example code for the DS1302 Real Time Clock, I want to perform an action at a specific date & time but cant get the syntax right, I tried the simple if statement below but this does not work, any pointers appreciated.
if (datestring == '06/02/2019 18:16:00')
Serial.println("Bingo");
// CONNECTIONS:
// DS1302 CLK/SCLK --> 5
// DS1302 DAT/IO --> 4
// DS1302 RST/CE --> 2
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <ThreeWire.h>
#include <RtcDS1302.h>
//ThreeWire myWire(4,5,2); // IO, SCLK, CE
ThreeWire myWire(8,2,10); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
char datestring[20];
void setup ()
// Real Time Clock Setup
Serial.print("compiled: ");
Serial.print(__DATE__);
Serial.println(__TIME__);
Rtc.Begin();
RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
printDateTime(compiled);
if (!Rtc.IsDateTimeValid())
// Common Causes:
// 1) first time you ran and the device wasn't running yet
// 2) the battery on the device is low or even missing
Serial.println("RTC lost confidence in the DateTime!");
Rtc.SetDateTime(compiled);
if (Rtc.GetIsWriteProtected())
Serial.println("RTC was write protected, enabling writing now");
Rtc.SetIsWriteProtected(false);
if (!Rtc.GetIsRunning())
Serial.println("RTC was not actively running, starting now");
Rtc.SetIsRunning(true);
RtcDateTime now = Rtc.GetDateTime();
if (now < compiled)
Serial.println("RTC is older than compile time! (Updating DateTime)");
else if (now > compiled)
Serial.println("RTC is newer than compile time. (this is expected)");
else if (now == compiled)
Serial.println("RTC is the same as compile time! (not expected but all is fine)");
void loop ()
printDateTime(now);
//Serial.println (datestring);
if (!now.IsValid())
// Common Causes:
// 1) the battery on the device is low or even missing and the power line was disconnected
delay(1000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
//char datestring[20];
snprintf_P(datestring,
countof(datestring),
PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
dt.Month(),
dt.Day(),
dt.Year(),
dt.Hour(),
dt.Minute(),
dt.Second() );
Serial.print(datestring);
