How to set APN?
I'm new to MKR 1500 and when I look at examples, the APN + login + password are set using:
gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)
But my code don't compile:
no matching function for call to 'GPRS::attachGPRS(const char [9], const char [8], const char [7])'
Is there a new way to set APN ?
Please post a link to the examples you found that show that.
Although it's not documented in the library reference, you can set the APN via NB::begin():
  /** Start the NB IoT modem, attaching to the NB IoT or LTE Cat M1 network
      @param pin         SIM PIN number (4 digits in a string, example: "1234"). If
                         NULL the SIM has no configured PIN.
      @param apn         (optional) APN to use
      @param restart     Restart the modem. Default is TRUE. The modem receives
                         a signal through the Ctrl/D7 pin. If it is shut down, it will
                         start-up. If it is running, it will restart. Takes up to 10
                         seconds
      @param synchronous If TRUE the call only returns after the Start is complete
                         or fails. If FALSE the call will return inmediately. You have
                         to call repeatedly ready() until you get a result. Default is TRUE.
      @return If synchronous, NB_NetworkStatus_t. If asynchronous, returns 0.
  NB_NetworkStatus_t begin(const char* pin = 0, bool restart = true, bool synchronous = true);
  NB_NetworkStatus_t begin(const char* pin, const char* apn, bool restart = true, bool synchronous = true);
  NB_NetworkStatus_t begin(const char* pin, const char* apn, const char* username, const char* password, bool restart = true, bool synchronous = true);
Note that it's an optional parameter.
Thanks a lot! Most examples are from other websites, the only one I found on arduino with APN is this one: https://www.arduino.cc/en/Tutorial/MKRNBToolsTestGPRS
JocPelletier:
Thanks a lot!
You're welcome. I'm glad if I was able to be of assistance.
JocPelletier:
That's no good. The interesting thing is that the erroneous code line doesn't occur in the "complete sketch" part of the tutorial, only the part of the tutorial that gives the code snippet. If you like, you can report this documentation error via this form:
I'm sure the future MKR NB 1500 users would be very grateful to not have to go through the same confusion you did.
Ok I reported the error, thanks again and it's working #1 with NB.begin
Will look at the code next time :confused:
Thanks for taking the time to make the world better for the Arduino community! I'm glad to hear it's working now. Enjoy!
