How to set delay from processing ?
Hello i am trying to set delay from processing knob. But when i set the delay on the processing knob the LED never goes off it stays ON forever .
This is my arduino code:
int theValue;
int theValue1;
pinMode(13,OUTPUT);
while(Serial.available() >0);
char val=Serial.read();
switch(val)
  case 'c':
  theValue=Serial.read();
  case 'd':
  theValue1=Serial.read();
case 'r':
digitalWrite(13,HIGH);
delay(theValue);
digitalWrite(13,LOW);
delay(theValue1);
This is my processing code:
import controlP5.*;
ControlP5 cp5a;
ControlP5 cp5b;
ControlP5 cp5c;
Knob myKnobA;
Knob myKnobB;
float n,n1;
import processing.serial.*;
Serial myPort;  // Create object from Serial class
String val;     // Data received from the serial port
 size(400,600);
 noStroke();
  String portName = Serial.list()[1]; //change the 0 to a 1 or 2 etc. to match your port
  myPort = new Serial(this, portName, 9600);
  cp5a = new ControlP5(this);
   cp5a.addButton("Blink")
     .setValue(0)
     .setPosition(100,100)
     .setSize(200,19)
     cp5b=new ControlP5(this);
      myKnobA = cp5b.addKnob("knobON")
               .setRange(0,1000)
               .setValue(50)
               .setPosition(150,200)
               .setRadius(50)
               .setDragDirection(Knob.VERTICAL)
                    cp5c=new ControlP5(this);
      myKnobB = cp5b.addKnob("knobOFF")
               .setRange(0,1000)
               .setValue(50)
               .setPosition(150,360)
               .setRadius(50)
void draw()
  background(0);
 public void Blink(){
   myPort.write('r');
 public void knobON(int theValue){
   myPort.write('c');
   myPort.write(theValue);
 public void knobOFF(int theValue1){
   myPort.write(298);
   myPort.write(theValue1);
Thank you.
As soon as there is something to read, loop forever.
If there's nothing to read, read it anyway.
How can i do that ?
I tried moving code to void setup but now it doesn't work.
Thing is, Serial.available() >0 also returns true if there is one ONE char. So you can only safely read a single char. And Serial is slow compared to the microcontroller going through the code, so probably there is only a single char in.
Or wait until you have received as many chars as you want to read, for example Serial.available() > 3.
Or make the code even better by making it more a state machine. See Serial Input Basics.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
...R
