Hello dear friends. I have Encoder OMRON E6B2-CWZ6C. When I rotate the encoder, the value on the screen goes up to 6400. But I want it to value the angle type, i want it to limit the values he gives to 360, so I want him to show 360 degrees when he turns a full lap. This is my current code. Can you help me with this code ?
volatile unsigned int counter = 0; //This variable will increase or decrease depending on the rotation of encoder
Serial.begin (9600);
pinMode(2, INPUT); // set pin to input
pinMode(3, INPUT); // set pin to input
digitalWrite(2, HIGH); // turn on pullup resistors
digitalWrite(3, HIGH); // turn on pullup resistors
//Setting up interrupt
//A rising pulse from encodenren activated ai0(). AttachInterrupt 0 is DigitalPin nr 2 on moust Arduino.
attachInterrupt(0, ai0, RISING);
//B rising pulse from encodenren activated ai1(). AttachInterrupt 1 is DigitalPin nr 3 on moust Arduino.
attachInterrupt(1, ai1, RISING);
// Send the value of counter
Serial.println (counter);
void ai0() {
// ai0 is activated if DigitalPin nr 2 is going from LOW to HIGH
// Check pin 3 to determine the direction
if(digitalRead(3)==LOW) {
counter++;
else{
counter--;
void ai1() {
// ai0 is activated if DigitalPin nr 3 is going from LOW to HIGH
// Check with pin 2 to determine the direction
if(digitalRead(2)==LOW) {
counter--;
}else{
counter++;
