How to set multiple bits simultaneously in a register
Hi there,
I'm using an ATtiny84 to blink two LEDs depending on a condition. Sometimes, it blinks only one LED, and the other blinks both. However, the code below sequentially lights up the LEDs. I know it's still fast for the human eye, but I wonder if anyone knows how I could set bits 4 and 5 of the PORTA register without changing the rest of the bits in the register.
#define OUT_L     4
#define OUT_R     5
bool bBit = 1;
  pinMode(OUT_R, OUTPUT);
  pinMode(OUT_L, OUTPUT);
  digitalWrite(OUT_R, LOW);
  digitalWrite(OUT_L, LOW);
      if (bBit){
        // digitalWrite(OUT_L, 1);
        // digitalWrite(OUT_R, 1);
        PORTA &=~(1<<(OUT_L));
        PORTA &=~(1<<(OUT_R));
      else{
        // digitalWrite(OUT_L, 0);
        // digitalWrite(OUT_R, 0);
        PORTA |=(1<<(OUT_L));
        PORTA |=(1<<(OUT_R));
  bBit = !bBit;
        PORTA &=~((1<<(OUT_L)) | (1<<(OUT_R)));
        PORTA |=((1<<(OUT_L)) | (1<<(OUT_R)));
Do you realise that your code only works by luck? You are lucky that the Arduino pin numbers, 4 & 5, happen, by chance, to be bits 4 & 5 in PORTA.
If you want to toggle the output pins, you can do this by writing a 1 to the corresponding bit in the PINA register.
thank you for the help.
appriciate it much!
