How to set Pin11 and Pin13 with HIGH and LOW output?
hello, experts:
I am trying to write driver for one SPI LCD(for UNO), but i don't know how to set Pin11 and Pin13 with HIGH and LOW output.
just like this:
#define PIN5_LOW {DDRD |= 0x20;PORTD &=~ 0x20;}
#define PIN5_HIGH {DDRD |= 0x20;PORTD |= 0x20;}
THANKS!!! ]:smiley:
Why don't you use the SPI library?
pylon:
because the SPI LCD have not D/C pin :sweat_smile:
D/C pin? What is that?
CrossRoads:
one pin of normal SPI LCD :smiley:
If its SPI then by definition it would have Clock, Data In, and Chip Select (slave select).
What are you saying yours does not have?
Do you have a link to yours?
CrossRoads:
there is not link for this 'special' SPI LCD.
but i can list all the pins of this LCD: VDD, CS, MOSI(SDI), SDO, SCK, RST, BL, GND
Its not "special" in any way. Just normal SPI. CS, MOSI(SDI), SDO, SCK, those are the standard SPI pins.
Mark
holmes4:
Mark
ok, actually, comparing with this SPI LCD(LCD display with ILI9341 driver on Arduino - Displays - Arduino Forum), there is not D/C pin at my SPI LCD .
if i want write cmd, i can do it like this:
void TFT::sendCMD(INT8U cmd)
digitalWrite(pin_cs, LOW);
digitalWrite(pin_sck, LOW);
digitalWrite(pin_sdi, LOW);
digitalWrite(pin_sck, HIGH);
SPI.transfer(cmd);
digitalWrite(pin_cs, HIGH);
I don't know whether i can write this function in TFT.cpp, because digitalWrite() is used in *.ino file.
so, i need one way(like this: ) to set CS, SCK, SDI Pin's HIGH and LOW ouput :sweat_smile:
    digitalWrite(pin_sck, LOW); << not needed - is controlled by SPI mode
    digitalWrite(pin_sdi, LOW);  << not needed - pin is ignore when CS is High
    digitalWrite(pin_sck, HIGH); << not needed
    SPI.transfer(cmd);                << SCK & SDI are toggled here
Why do you think the extra control changes are needed?
CrossRoads:
thanks for your comments.
because i have tested this LCD with normal I/O pin by output HIGH/LOW and it works, but the display speed is toooo slowly, so, i try the SPI way and i want to port this code ]:smiley:
int pin_bl = 3;
int pin_cs = 4;
int pin_sdi = 5;
int pin_sck = 6;
int pin_rst = 7;
//write one byte by SPI
void TFT_SPI_Write_Byte(byte num)
    int count=0;
    for( count=0; count<8; count++ )
        if(num&0x80)
            digitalWrite(pin_sdi, HIGH);
        num<<=1;
// write command one byte
void LCD_WR_REG(byte cmd)
    TFT_SPI_Write_Byte(cmd);
    // arduino pin setting, IO for SPI
    pinMode(pin_bl, OUTPUT);
    pinMode(pin_cs, OUTPUT);
    pinMode(pin_sdi, OUTPUT);
    pinMode(pin_sck, OUTPUT);
    pinMode(pin_rst, OUTPUT);
    // clear and reset LCD buffer
    digitalWrite(pin_bl, LOW);
    digitalWrite(pin_rst, LOW);
    delay(10);
    digitalWrite(pin_rst, HIGH);
    // init lcd
    lcd_init();
    LCD_Clear(0x0000);
    //line
    LCD_DrawLine(0, 0, 240, 320);
D/C means that the pin is not connected!. Look in the datasheet you will be given the meanings and use of each PIN.
Mark
