how to set PWM at 120Hz
Hi to all,
I have read that standard frequency for the PWM is about 488 Hz, but I need to lower it to 120 Hz for my project.
What us the easiest and most robust way to do this?
I’ve read about a solution based on adjusting the timers.
Is this the only way?
Do you have any sample to study/test?
Thank you!
Look at the TimerOne library.
So, I should set the period to 8333.3333333333 microseconds if I need a pwm at 120 hz?
For example, pwm(9, 512, 8333.3)?
Since I need to change the duty cycle, can I pass the duty cycle as a parameter to thus function?
This would give you ~120HZ
#include <TimerOne.h>
  pinMode(9, OUTPUT);
  Timer1.initialize(8333);
  Timer1.pwm(9, 512);
Yes you can change the duty cycle as needed:
Timer1.pwm(9, myDutyCycle);
LarryD: Yes you can change the duty cycle as needed:
Can I put his even in the main loop? Or only in the setup?
Yes.
