How to set sleep mode for Feather M0 Bluefruit
Hello,
I would like to save power consumption when the object temperature is tested. However, I do not know how to set sleep mode for Feather M0 Bluefruit to save the power consumption. Dose any one achieve it before? Thanks in advance.
Kind regards,
Tang
tangtangdn:
Hello,
Kind regards,
Tang
What is your project?
Do you have a wiring diagram of your project?
More detail is required.
artisticforge:
Hello,
I just connect GY-906 infrared temperature sensor to Feather M0 Bluefruit. The pin connection is shown as below (Sorry, I do not know how to paste a picture here)
Vin–3V
GND–GND
SCL–SCL
SDA–SDA
The sample frequency is about 1Hz. However, the power consumption is up to 36mW (about 3V*12mA). I want to reduce the power consumption. Could you give some good ideas? Thanks a lot.
Regards,
Tang
Hi Tang,
It might be worth checking out the RTC (Real Time Clock) library: Arduino - RTC.
It has a function called standbyMode() that puts the processor to sleep, although in the source code a comment says that it causes issues when the board is connected via the native USB port. The source code can be found here: https://github.com/arduino-libraries/RTCZero.
There's also an example SleepRTCAlarm: https://www.arduino.cc/en/Tutorial/SleepRTCAlarm.
MartinL:
Hi Tang,
Thanks Martin.
