how to setup an ISR
Following is the code. Do I need to make a function to ISR? If so, how and where should I call ISR?
Snippets of codes I got from somewhere but need to put together in a working program.
//  VARIABLES
int pulsePin = 0;                 // Pulse Sensor purple wire connected to analog pin 0
int blinkPin = 13;                // pin to blink led at each beat
int fadePin = 5;                  // pin to do fancy classy fading blink at each beat
int fadeRate = 0;                 // used to fade LED on with PWM on fadePin
// these variables are volatile because they are used during the interrupt service routine!
volatile int BPM;                   // used to hold the pulse rate
volatile int Signal;                // holds the incoming raw data
volatile int IBI = 600;             // holds the time between beats, the Inter-Beat Interval
volatile boolean Pulse = false;     // true when pulse wave is high, false when it's low
volatile boolean QS = false;        // becomes true when Arduoino finds a beat.
void setup(){
  pinMode(blinkPin,OUTPUT);         // pin that will blink to your heartbeat!
  pinMode(fadePin,OUTPUT);          // pin that will fade to your heartbeat!
  Serial.begin(115200);             // we agree to talk fast!
  interruptSetup();                 // sets up to read Pulse Sensor signal every 2mS
   // UN-COMMENT THE NEXT LINE IF YOU ARE POWERING The Pulse Sensor AT LOW VOLTAGE,
   // AND APPLY THAT VOLTAGE TO THE A-REF PIN
   //analogReference(EXTERNAL);
void loop(){
  sendDataToProcessing('S', Signal);     // send Processing the raw Pulse Sensor data
  if (QS == true){                       // Quantified Self flag is true when arduino finds a heartbeat
        fadeRate = 255;                  // Set 'fadeRate' Variable to 255 to fade LED with pulse
        sendDataToProcessing('B',BPM);   // send heart rate with a 'B' prefix
        sendDataToProcessing('Q',IBI);   // send time between beats with a 'Q' prefix
        QS = false;                      // reset the Quantified Self flag for next time
  ledFadeToBeat();
  delay(20);                             //  take a break
void ledFadeToBeat(){
    fadeRate -= 15;                         //  set LED fade value
    fadeRate = constrain(fadeRate,0,255);   //  keep LED fade value from going into negative numbers!
    analogWrite(fadePin,fadeRate);          //  fade LED
void sendDataToProcessing(char symbol, int data ){
    Serial.print(symbol);                // symbol prefix tells Processing what type of data is coming
    Serial.println(data);                // the data to send culminating in a carriage return
volatile int rate[10];                    // used to hold last ten IBI values
volatile unsigned long sampleCounter = 0;          // used to determine pulse timing
volatile unsigned long lastBeatTime = 0;           // used to find the inter beat interval
volatile int P =512;                      // used to find peak in pulse wave
volatile int T = 512;                     // used to find trough in pulse wave
volatile int thresh = 512;                // used to find instant moment of heart beat
volatile int amp = 100;                   // used to hold amplitude of pulse waveform
volatile boolean firstBeat = true;        // used to seed rate array so we startup with reasonable BPM
volatile boolean secondBeat = true;       // used to seed rate array so we startup with reasonable BPM
void interruptSetup(){
  // Initializes Timer2 to throw an interrupt every 2mS.
  TCCR2A = 0x02;     // DISABLE PWM ON DIGITAL PINS 3 AND 11, AND GO INTO CTC MODE
  TCCR2B = 0x06;     // DON'T FORCE COMPARE, 256 PRESCALER
  OCR2A = 0X7C;      // SET THE TOP OF THE COUNT TO 124 FOR 500Hz SAMPLE RATE
  TIMSK2 = 0x02;     // ENABLE INTERRUPT ON MATCH BETWEEN TIMER2 AND OCR2A
  sei();             // MAKE SURE GLOBAL INTERRUPTS ARE ENABLED
// THIS IS THE TIMER 2 INTERRUPT SERVICE ROUTINE.
// Timer 2 makes sure that we take a reading every 2 miliseconds
[b]ISR(TIMER2_COMPA_vect)[/b]{                         // triggered when Timer2 counts to 124
    cli();                                      // disable interrupts while we do this
    Signal = analogRead(pulsePin);              // read the Pulse Sensor
    sampleCounter += 2;                         // keep track of the time in mS with this variable
    int N = sampleCounter - lastBeatTime;       // monitor the time since the last beat to avoid noise
//  find the peak and trough of the pulse wave
    if(Signal < thresh && N > (IBI/5)*3){       // avoid dichrotic noise by waiting 3/5 of last IBI
        if (Signal < T){                        // T is the trough
            T = Signal;                         // keep track of lowest point in pulse wave
    if(Signal > thresh && Signal > P){          // thresh condition helps avoid noise
        P = Signal;                             // P is the peak
       }                                        // keep track of highest point in pulse wave
  //  NOW IT'S TIME TO LOOK FOR THE HEART BEAT
  // signal surges up in value every time there is a pulse
if (N > 250){                                   // avoid high frequency noise
  if ( (Signal > thresh) && (Pulse == false) && (N > (IBI/5)*3) ){
    Pulse = true;                               // set the Pulse flag when we think there is a pulse
    digitalWrite(blinkPin,HIGH);                // turn on pin 13 LED
    IBI = sampleCounter - lastBeatTime;         // measure time between beats in mS
    lastBeatTime = sampleCounter;               // keep track of time for next pulse
         if(firstBeat){                         // if it's the first time we found a beat, if firstBeat == TRUE
             firstBeat = false;                 // clear firstBeat flag
             return;                            // IBI value is unreliable so discard it
         if(secondBeat){                        // if this is the second beat, if secondBeat == TRUE
            secondBeat = false;                 // clear secondBeat flag
               for(int i=0; i<=9; i++){         // seed the running total to get a realisitic BPM at startup
                    rate[i] = IBI;
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
Please use code tags.
Read this before posting a programming question
How to use this forum
http://www.gammon.com.au/interrupts
ISR() is actually a fairly complex macro that only looks like a function. If you copy examples online, it is quite easy to use. It looks like you are on the right track.
Something has happened to your formatting right at the end. I can't tell if the function is closed properly.
