the API docs say, that I can setup the serial port config (parity etc..) with an optional 2nd argument in Serial.begin(...) ... This work's perfectly for leonardo, micro, ...
If I check the mentioned header file, the begin() method has indeed just one argument, for baudrate. That's it. NO 2nd argument for serial port configuration.
So how do I setup the parity for this device's serial?
br,
Alex
P.S. Using Arduinoi IDE 1.6.6 with SAMD Core 1.6.2
Just tried the following line in the sketch's setup{}, in IDE 1.6.6, samd core 1.6.2:
Serial1.begin(115200, SERIAL_8E1);
This compiles OK.
In the Arduino Zero core, HardwareSerial is an abstract class and has no implementation. Instead it's the UART class that inherits the HardwareSerial's interface and implements the Serial functions.
The UART class in turn calls on the SERCOM class. It's the SERCOM class that manipulates the Zero's serial port registers.
