Hi, just to remind, im new to arduino so alot is a learning curve.
At the moment i have my arduino and LCD working great but my intentions is to also have an SD card break out connected but looking at the wiring the LCD and SD card use the same pins, and it says the SD needs to use these particular pins? (is this so and if so, is this the same case with the LCD?).
There is one hardware highspeed serial port for SPI/I2C/etc on an UNO. But there are examples for doing SPI/I2C/etc using other pins driven by software (sketch) not only on the Arduino site but on the ATMEL site as Application Notes. Keys words: soft SPI.
It's hard to imagine the LCD needing full blast SPI. That's the one I'd go 'soft' on.
Hi, thanks both. Your right (which im sure you new ) ive swapped the lcd pins to two others and it works fine. (should of done this in the first place)
