How to: soil moisture measurement?
If I don't want the part for the twitter message, what I've to do to the project so that the result will just appear on the arduino software? Can somebody teach me how to do it. http://www.botanicalls.com/archived_kits/twitter/ This is the link I refer to. Thank You.
Is anyone here had an experience in order to build Soil Moisture Sensor? If there any, can u share ur knowledge with me because I never do this kind of project before by using arduino. Actually my project is about to detect the soil moisture by using Vegetronix VG400 Soil Moisture Sensor probes. It will change the analog to digital value so that it can be easily determine the moisture. If the moisture too dry (RED LED blinking), if the moisture wet (GREEN LED blinking) and if the condition of the soil is not too dry and wet (YELLOW LED blinking). I also wanna make an alarm when the moisture too dry. Can somebody help me to figure it. Thank You
You want to make one or buy one? If you want to buy one, go ahead. You have our permission. Not our paypal number or credit card, though.
Typically, red and yellow indicate problem conditions, and green means good.
I'd suggest a wave shield with some of these: http://www.songarea.com/music-codes/dry.html
What's left to figure out? Just the threshold between too wet/just right and between just right/too dry, and that will depend on the plant(s) you are monitoring.
Thanks for the reply. Actually what I means from the previous post is how to do the coding part. Is there any link which I can refer to?
Sure. http://arduino.cc/en/Reference/HomePage
thanks a lot :)
