IDE 2.2.1
UNO R3
In this project I am receiving two floats to be displayed on a LCD(see code below):
byte lcdDisplayAddress = 0x27;
#include <Wire.h>
#define LCD2004 true
LiquidCrystal_I2C LCD(lcdDisplayAddress, 20, 4); // set the LCD address to 0x27 for a 20 chars and 4 line display
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__)
//this will compile for Arduino UNO, Pro and older boards
int _sck = 13;
int _miso = 12;
int _mosi = 11;
#elif defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
//this will compile for Arduino Mega
int _sck = 52;
int _miso = 50;
int _mosi = 51;
#endif
#if defined(ARDUINO) && ARDUINO >= 100 // Arduino v1.0 and newer
#define I2C_WRITE Wire.write
#define I2C_READ Wire.read
#else // Arduino Prior to v1.0
#define I2C_WRITE Wire.send
#define I2C_READ Wire.receive
#endif
while (!Serial) {}; // Leonardo: wait for Serial Monitor
Serial.println("\nXtrack Receiver");
#ifdef LCD2004
Wire.begin();
LCD.init(); // initialize the lcd
LCD.backlight();
LCD.setCursor(0, 0); // Set the cursor on the third column and first row.
LCD.print("XTRACK-Connect Test"); //
#endif
float AXrotor;
float EYrotor;
while (Serial.available()) { // If anything comes in Serial (USB)
AXrotor = Serial.parseFloat();
EYrotor = Serial.parseFloat();
Serial.println(AXrotor);
Serial.println(EYrotor);
#ifdef LCD2004
LCD.setCursor(0, 1);
LCD.print(AXrotor);
LCD.setCursor(0, 2);
LCD.print(EYrotor);
#endif
If I enter, using the serialmonitor, this number: 123.45,678.90
the output looks like this:
06:19:06.695 -> Xtrack Receiver
06:19:52.039 -> 123.45
06:19:52.039 -> 678.90
06:19:54.030 -> 0.00
The first three are as expected but the last two lines are not. How do I supress the last two lines??
