How to solve Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled
Hi i am getting this error when i try to connent my esp32 to this code.
   //         ESP32 Weather Station Project     v1.00             //
  //       Get the latest version of the code here:              //
 //         http://educ8s.tv/esp32-weather-station              //
#define ARDUINOJSON_ENABLE_PROGMEM 0
#include <Wire.h>
#include "Adafruit_BME280.h" //https://github.com/Takatsuki0204/BME280-I2C-ESP32
#include <ArduinoJson.h>    //https://github.com/bblanchon/ArduinoJson
#include <WiFi.h>
Adafruit_BME280 bme; // I2C
const char* ssid     = "";
const char* password = "!";
String CityID = "253394"; //Sparta, Greece
String APIKEY = "";
#define ALTITUDE 216.0 // Altitude in Sparta, Greece
//#define I2C_SDA 21
//#define I2C_SCL 22
#define LED_PIN 2
//#define BME280_ADDRESS 0x76  //If the sensor does not work, try the 0x77 address as well
float temperature = 0;
float humidity = 0;
float pressure = 0;
int weatherID = 0;
//Adafruit_BME280 bme(I2C_SDA, I2C_SCL);
WiFiClient client;
char* servername ="api.openweathermap.org";  // remote server we will connect to
String result;
int  iterations = 1800;
String weatherDescription ="";
String weatherLocation = "";
float Temperature;
  pinMode(LED_PIN, OUTPUT);
  initSensor();
  connectToWifi();
 delay(2000);
 if(iterations == 1800)//We check for updated weather forecast once every hour
   getWeatherData();
   printWeatherIcon(weatherID);
   iterations = 0;
 delay(2000);
 getTemperature();
 sendTemperatureToNextion();
 getHumidity();
 sendHumidityToNextion();
 getPressure();
 sendPressureToNextion();
 iterations++;
 blinkLED();
void connectToWifi()
  WiFi.enableSTA(true);
  delay(2000);
  WiFi.begin(ssid, password);
        Serial.print(".");
void initSensor()
  //bool status = bme.begin(BME280_ADDRESS);
  if (!(bme.begin(118))) {
    Serial.println("Could not find a valid BME280 sensor, check wiring!");
    while (1);
void blinkLED()
  digitalWrite(LED_PIN,HIGH);
  delay(100);
  digitalWrite(LED_PIN,LOW);
float getTemperature()
  temperature = bme.readTemperature();
float getHumidity()
  humidity = bme.readHumidity();
float getPressure()
  pressure = bme.readPressure();
  pressure = bme.seaLevelForAltitude(ALTITUDE,pressure);
  pressure = pressure/100.0F;
void getWeatherData() //client function to send/receive GET request data.
  String result ="";
  WiFiClient client;
  const int httpPort = 80;
  if (!client.connect(servername, httpPort)) {
        return;
      // We now create a URI for the request
    String url = "/data/2.5/forecast?id="+CityID+"&units=metric&cnt=1&APPID="+APIKEY;
       // This will send the request to the server
    client.print(String("GET ") + url + " HTTP/1.1\r\n" +
                 "Host: " + servername + "\r\n" +
                 "Connection: close\r\n\r\n");
    unsigned long timeout = millis();
    while (client.available() == 0) {
        if (millis() - timeout > 5000) {
            client.stop();
            return;
    // Read all the lines of the reply from server
    while(client.available()) {
        result = client.readStringUntil('\r');
result.replace('[', ' ');
result.replace(']', ' ');
char jsonArray [result.length()+1];
result.toCharArray(jsonArray,sizeof(jsonArray));
jsonArray[result.length() + 1] = '\0';
StaticJsonBuffer<1024> json_buf;
JsonObject &root = json_buf.parseObject(jsonArray);
if (!root.success())
  Serial.println("parseObject() failed");
String location = root["city"]["name"];
String temperature = root["list"]["main"]["temp"];
String weather = root["list"]["weather"]["main"];
String description = root["list"]["weather"]["description"];
String idString = root["list"]["weather"]["id"];
String timeS = root["list"]["dt_txt"];
weatherID = idString.toInt();
Serial.print("\nWeatherID: ");
Serial.print(weatherID);
endNextionCommand(); //We need that in order the nextion to recognise the first command after the serial print
void showConnectingIcon()
  String command = "weatherIcon.pic=3";
  Serial.print(command);
void sendHumidityToNextion()
  String command = "humidity.txt=\""+String(humidity,1)+"\"";
void sendTemperatureToNextion()
  String command = "temperature.txt=\""+String(temperature,1)+"\"";
void sendPressureToNextion()
  String command = "pressure.txt=\""+String(pressure,1)+"\"";
void endNextionCommand()
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
void printWeatherIcon(int id)
 switch(id)
  case 800: drawClearWeather(); break;
  case 801: drawFewClouds(); break;
  case 802: drawFewClouds(); break;
  case 803: drawCloud(); break;
  case 804: drawCloud(); break;
  case 200: drawThunderstorm(); break;
  case 201: drawThunderstorm(); break;
  case 202: drawThunderstorm(); break;
  case 210: drawThunderstorm(); break;
  case 211: drawThunderstorm(); break;
  case 212: drawThunderstorm(); break;
  case 221: drawThunderstorm(); break;
  case 230: drawThunderstorm(); break;
  case 231: drawThunderstorm(); break;
  case 232: drawThunderstorm(); break;
  case 300: drawLightRain(); break;
  case 301: drawLightRain(); break;
  case 302: drawLightRain(); break;
  case 310: drawLightRain(); break;
  case 311: drawLightRain(); break;
  case 312: drawLightRain(); break;
  case 313: drawLightRain(); break;
  case 314: drawLightRain(); break;
  case 321: drawLightRain(); break;
  case 500: drawLightRainWithSunOrMoon(); break;
  case 501: drawLightRainWithSunOrMoon(); break;
  case 502: drawLightRainWithSunOrMoon(); break;
  case 503: drawLightRainWithSunOrMoon(); break;
  case 504: drawLightRainWithSunOrMoon(); break;
  case 511: drawLightRain(); break;
  case 520: drawModerateRain(); break;
  case 521: drawModerateRain(); break;
  case 522: drawHeavyRain(); break;
  case 531: drawHeavyRain(); break;
  case 600: drawLightSnowfall(); break;
  case 601: drawModerateSnowfall(); break;
  case 602: drawHeavySnowfall(); break;
  case 611: drawLightSnowfall(); break;
  case 612: drawLightSnowfall(); break;
  case 615: drawLightSnowfall(); break;
  case 616: drawLightSnowfall(); break;
  case 620: drawLightSnowfall(); break;
  case 621: drawModerateSnowfall(); break;
  case 622: drawHeavySnowfall(); break;
  case 701: drawFog(); break;
  case 711: drawFog(); break;
  case 721: drawFog(); break;
  case 731: drawFog(); break;
  case 741: drawFog(); break;
  case 751: drawFog(); break;
  case 761: drawFog(); break;
  case 762: drawFog(); break;
  case 771: drawFog(); break;
  case 781: drawFog(); break;
  default:break;
void drawFog()
  String command = "weatherIcon.pic=13";
void drawHeavySnowfall()
  String command = "weatherIcon.pic=8";
void drawModerateSnowfall()
void drawLightSnowfall()
  String command = "weatherIcon.pic=11";
void drawHeavyRain()
  String command = "weatherIcon.pic=10";
void drawModerateRain()
  String command = "weatherIcon.pic=6";
void drawLightRain()
void drawLightRainWithSunOrMoon()
  String command = "weatherIcon.pic=7";
void drawThunderstorm()
void drawClearWeather()
  String command = "weatherIcon.pic=4";
void drawCloud()
  String command = "weatherIcon.pic=9";
void drawFewClouds()
  String command = "weatherIcon.pic=5";
Core 1 register dump:
PC : 0x400d292a PS : 0x00060f30 A0 : 0x800d3cad A1 : 0x3ffcab10
A2 : 0x000007d0 A3 : 0xf741e4df A4 : 0x3ffc3cd4 A5 : 0x3ffcab0c
A6 : 0x3ffca640 A7 : 0x3ffca640 A8 : 0x3ffc3820 A9 : 0x3ffcaaf0
A10 : 0x41ac28f6 A11 : 0x3ffbf638 A12 : 0x0000000a A13 : 0x3ffc3cd4
A14 : 0x00000007 A15 : 0x00000001 SAR : 0x0000001f EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x4008963c LEND : 0x40089652 LCOUNT : 0xffffffff
Backtrace: 0x400d2927:0x3ffcab10 0x400d3caa:0x3ffcab30 0x400d8175:0x3ffcab50
Run the esp exception analyzer and post the results.
Hi @ome_cor ,
Welcome to the forum..
hmm..
Looks like it crashes leaving getTemperature()..
All your functions have a return type of float but you never return anything??
maybe try adding a return temperature; or make them all void..
good luck.. ~q
Seems like some other part of your code corrupted your stack, overwriting a return address, and causing a jump to an address that does not contain executable code. You should check for buffer overflows or other sources of undefined behavior.
After a quick look, here's at least one VLA buffer overflow:
You should not use VLAs, they are non-standard, unsafe, and can cause stack overflows on embedded systems.
Use a std::string or a std::vector<char> if you need a dynamic buffer of characters. (Although that's wasteful in this case, you already have the data in a buffer, namely the String result.)
