How to solve this problem? "esptool.FatalError: Failed to connect to ESP8266:"
Hi! how to solve this problem? thank you :slight_smile:
I'm using Windows 10 and Arduino Uno to program ESP8266 - ESP-01 wifi module
An error occurred while uploading the sketch
esptool.py v2.8
Serial port COM8
Connecting......................................___
Traceback (most recent call last):
File "C:\Users\acer\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3/tools/upload.py", line 65, in
esptool.main(cmdline)
File "C:/Users/acer/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/acer/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
I've deleted your other cross-post @Mmors13.
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a suspension from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky "How to use this forum - please read." post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
