How to solve this
I want to control my rbddimeer using remote but i am getting error please can anyone help me how to solve it
libraries\RBDDimmer-master\avr\RBDmcuAVR.cpp.o (symbol from plugin): In function `dimmerLamp::dimmerLamp(int)':
(.text+0x0): multiple definition of `__vector_7'
libraries\IRremote\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
Hi @jamsyogendra ,
It solves like this:
look if it's there, if it's not then measure it, then fix it.
RV mineirin
Sorry I don't get it
w/o seeing the code all that can be said is "__vector_7" is defined more than once. one definition needs to be removed
Have you tried posting the code that causes the error? That way people can look at the error message and look at the code and put 9 and 12 together to get an answer.
Solved! i just upgrade the IRremote Lib 3.3v
what is a "rbddimeer" ???
You should post your complete code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
OK, I will remember next time.
3:15:38.309 -> The function decode(&results)) is deprecated and may not work as expected! Just use decode() without a parameter and IrReceiver.decodedIRData. .
new day, new error
