How to spellcheck, whether IP-Adress is correctly send
Hi friends,
I am currently programming an ESP8266 12E.
My aim is this:
The user have to type in its IP-Adress via HTML-INPUT Field.
My Software has to check, whether the User (Client) has typed in the Adress in a correctly form, like this 192.168.11.4 <-- so it must be all numeric, 3 dots must be their.
How can I do this ?
I have found a code, but this is not indeed, a numeric check.:
String str = "192.168.2.1"; // <-- this is an example to spellcheckString
// String str = "h192.168.2.1"; // <-- this for example, could be a wrongfully spelled address
String strs[5];
int StringCount = 0;
void setup (void)
  Serial.begin (115200);
  delay(200);
  while (str.length() > 0)
    int index = str.indexOf('.');
    if (index == -1) // No Dot found
      strs[StringCount++] = str;
      strs[StringCount++] = str.substring(0, index);
      str = str.substring(index+1);
  for (int i = 0; i < StringCount; i++)
    long myInt = strs[i].toInt();
    // I have tried this for a spellcheck
    // but if you put for example a small 'h', than a Zero comes out of the integer
    // But Zeros are also used as an IP Adress
    if(myInt < 1000)
    Serial.println(myInt);
void loop () {}
Perhaps this could help.
wait will try
i can not test it:
allways this error apear:
invalid conversion from 'char*' to 'int' [-fpermissive]
char * myChar = "65465";
  if (isDigit(myChar)) {  // tests if myChar is a digit
    Serial.println("The character is a number");
  else {
    Serial.println("The character is not a number");
This has probably been done a hundred times before, but here goes.
bool isByte(int const number) {
  return number >= 0 and number < 256;
bool isValid(char const* text) {
  return isDigit(text[0]) and text[0] != '0' and isByte(atoi(text));
bool isIP(char const* text) {
  size_t startPos = 0;
  size_t pos = 0;
  size_t dots = 0;
  while (text[pos]) {
    if (not isDigit(text[pos])) {
      if (not (text[pos] == '.' and isValid(&text[startPos]))) {
        return false;
      startPos = pos + 1;
      dots++;
    pos++;
  return isValid(&text[startPos]) and dots == 3;
thanks, but where I have to put the IP-Adress to check ?
plese note: I am a beginner.
And where is the setup() and loop() ?
I have just ran the code you given, and and Error occures.
The rest of the sketch could look as follows.
  Serial.println(isIP("192.168.2.1"));
  Serial.println(isIP("192.168.2"));
  Serial.println(isIP("192.168.2.1.3"));
  Serial.println(isIP("192.168.2.333"));
  Serial.println(isIP("292.168.2.1"));
  Serial.println(isIP("f92.168.2.1"));
  Serial.println(isIP("19f.168.2.1"));
void loop() {}
This will print 1 for the first string and 0 for the rest of the strings.
Thanks it works :smiley:
But:
But why are these both not Ip-Adresses ?
192.168.2.333
292.168.2.1
Because every number represents one byte of the 32-bit IP address and a byte can only hold numbers between 0 and 255.
thanks man... you made my day :smiley:
I am really really grateful :upside_down_face:
Note that I edited the functions to reject stuff like "192.168..1" and "192.168.02.1".
okay, I really thank you man :smiley:
greetings fron Germany, Bielefeld
