How to split numbers in the arduino code?
I'm hav ing some problems on separating numbers that I recived from my app inventor using the hc-06 bluetooth module.
here is my code in arduino:
String readString;
int delimiter, delimiter_1, delimiter_2, delimiter_3, delimiter_4, delimiter_5, delimiter_6, delimiter_7;
if (Serial.available() > 0)
readString = Serial.read();
delimiter = readString.indexOf("59");
delimiter_1 = readString.indexOf("59", delimiter + 1); // this 59 is equal the ";" on the app inventor
delimiter_2 = readString.indexOf("59", delimiter_1 + 1);
delimiter_3 = readString.indexOf("59", delimiter_2 + 1);
delimiter_4 = readString.indexOf("59", delimiter_3 + 1);
delimiter_5 = readString.indexOf("59", delimiter_4 + 1);
delimiter_6 = readString.indexOf("59", delimiter_5 + 1);
int a = readString.substring(delimiter + 1, delimiter_1).toInt();
int b = readString.substring(delimiter_1 + 1, delimiter_2).toInt();
int c = readString.substring(delimiter_2 + 1, delimiter_3).toInt();
int d = readString.substring(delimiter_3 + 1, delimiter_4).toInt();
int e = readString.substring(delimiter_4 + 1, delimiter_5).toInt();
int f = readString.substring(delimiter_5 + 1, delimiter_6).toInt();
Serial.println(f);
here is my code in app inventor
So my problem is the app inventor sends everything together, and I need to split them, but I don't know how to do this.
If someone knows, please help me!
Serial.read returns a single int.
Not a whole String.
Please remember to use code tags when posting code
Doesn't it return a char, a byte?
No, it doesn't, it returns an int.
Easy enough to check.
Oh. A surprise to me. I'll have to check for char sgn = Serial.read in my old codes.
It's a legacy feature. It's an int so a -1 code can be returned as an error condition. You can continue to ignore it and assign to a char type at will, since you already checked the "unavailable" condition with available().
Take a short look at the beginning of loop(). Char Sa compiles without remarks.
[code]
  pinMode (9, OUTPUT);//blue colour
  pinMode (10, OUTPUT);//red colour
  pinMode (11, OUTPUT);//green coour
  analogWrite(9, 125);//turn on blue colour
  Serial.print("125 ");//ijkltell on Serial
  delay(5000);//give spectator time to verify function
  analogWrite(9, 0);//turn off blue
  analogWrite(10, 125);//turn on red
  Serial.print("125 ");//tell on Serial
  analogWrite(10, 0);//turn of red
  analogWrite(11, 125);//turn on green
  Serial.println("125 ");//tell on Serial
  analogWrite(11, 0);//turn off green
  int i, j, k;//the three colour loop varibles
  int debugDisplay;//value to be displyed if defined name is given
  bool debugFlag;//debug flag telling valid variable is received
  char Sa;//debugged variable name to be displayed
  for ( i = 0; i < 25; i = i + 1)//loop for blue
    for ( j = 0; j < 25; j = j + 1)//loop for red
      for ( k = 0; k < 25; k = k + 1)//loop for green
        debugFlag = false;//initiate flag for displaying value
        if (Serial.available())//if debug order from keyboard
          Sa = Serial.read();//get the name for variable to disply
          switch (Sa) {
            case 'A'://name is 'A', display its variable in switch case below
                debugDisplay = i;//display correct variable value in case below
                debugFlag = true;//tell valid debug name was received
            case 'B'://name is 'B', display its variable in switch case below
                debugDisplay = j;//display correct variable in case below
            case 'C'://name is 'C', display its variable in switch case below
                debugDisplay = k; //display correct variable in case below
            default:
              //              debugFlag = false;
          }//end of switch
          if (debugFlag)//print out if valid debug from Serial
            Serial.print(Sa); Serial.print(" = ");//name of variable
            Serial.println(debugDisplay);// actual variable value
            debugFlag = false;//turn off display, vslue displeyd above
        analogWrite(9, i);//PWM for blue
        analogWrite(10, j);//PWM for green
        analogWrite(11, k);//PWM for red
  delay(20);
[/code]
Should give an "implicit narrowing" warning, I think.
It didn't! I wide opened the the error window and found no remarks what so ever. Only the memory usage!
I guess for Arduino, enabling the compiler's "-Wconversion" option would open up a massive can of worms. :roll_eyes:
The version, the setup is what I got when downloaded the IDE. No adjustments made by me.
int value = Serial.parseInt();will throw away characters until it finds something that looks like a number, then accept characters until it finds one that doesn't look like a number or times out (1 second), then returns the value of the number. Call it once for each number you expect to receive.
I'm writing to add some information for my doubt in order to be more informative.
So my problem is that I need to slip the numbers that I receive from the app inventor. The app sends to my serial , for example, the numbers 1,2,3,4,5,6. I created a variable (INT) for A,B,C,D,E,F; and I want to split each letter for each number. Then I print some letter, (A), and the results have to be the first number, in this case number 1.
I’ve already created a program, but it doesn't work, because when I print some letter (A), it shows me all the numbers (1,2,3,4,5,6).
In app inventor I put a semicolon between the textbox (numbers) trying to split them, and make the program easier in arduino code, but when I send the number with the semicolon, the same appears as a number 59. As a result, the serial shows this: 59,1,59,2,59,3,59,4,59,5,59,6.
what I need to do?
I already sent my app inventor blocks and the arduino code, but to add, here is my designer from the app:
And, to show what is happening, here is my Serial, from arduino.
I hope that this information could be helpful to solve my problem.
