How to split RGB to int?
Hello,
I have a color sensor that returns RGB values (string) in the form RRR,GGG,BBB. How do I split up this serial data so that I have 3 separate integers? This is the sample code from the color sensor site:
This software was made to demonstrate how to quickly get your Atlas Scientific product running on the Arduino platform.
An Arduino Duemilanove board was used to test this code.
This code was written in the Arudino 1.0 IDE
Modify the code to fit your system.
Code efficacy was NOT considered, this is a demo only.
The soft serial port TX line goes to the RX pin.
The soft serial port RX line goes to the TX pin.
Make sure you also connect to power and GND pins to power and a common ground.
Data is received and re-sent through the Arduinos hardware UART TX line.
Open TOOLS > serial monitor, set the serial monitor to the correct serial port and set the baud rate to 38400.
Remember, select carriage return from the drop down menu next to the baud rate selection; not "both NL & CR".
The data from the Atlas Scientific product will come out on the serial monitor.
Type in a command in the serial monitor and the Atlas Scientific product will respond.
#include <SoftwareSerial.h>                                                    //add the soft serial libray
#define rxpin 2        //set the RX pin to pin 2
#define txpin 3        //set the TX pin to pin 3
SoftwareSerial myserial(rxpin, txpin);                                         //enable the soft serial port
String inputstring = "";                                                       //a string to hold incoming data from the PC
String sensorstring = "";                                                      //a string to hold the data from the Atlas Scientific product
boolean input_stringcomplete = false;                                          //have we received all the data from the PC
boolean sensor_stringcomplete = false;                                         //have we received all the data from the Atlas Scientific product
  void setup(){        //set up the hardware
     Serial.begin(38400);                                                      //set baud rate for the hardware serial port to 38400
     myserial.begin(38400);                                                    //set baud rate for software serial port to 38400
     inputstring.reserve(5);                                                   //set aside some bytes for receiving data from the PC
     sensorstring.reserve(30);                                                 //set aside some bytes for receiving data from Atlas Scientific product
   void serialEvent() {                                                         //if the hardware serial port receives a char
               char inchar = (char)Serial.read();                               //get the char we just received
               inputstring += inchar;                                           //add it to the inputString
               if(inchar == '\r') {input_stringcomplete = true;}                //if the incoming character is a <CR>, set the flag
 void loop(){        //here we go....
  if (input_stringcomplete){                                                   //if a string from the PC has been recived in its entierty
      myserial.print(inputstring);                                             //send that string to the Atlas Scientific product
      inputstring = "";                                                        //clear the string:
      input_stringcomplete = false;                                            //reset the flage used to tell if we have recived a completed string from the PC
  while (myserial.available()) {                                               //while a char is holding in the serial buffer
         char inchar = (char)myserial.read();                                  //get the new char
         sensorstring += inchar;                                               //add it to the sensorString
         if (inchar == '\r') {sensor_stringcomplete = true;}                   //if the incoming character is a <CR>, set the flag
   if (sensor_stringcomplete){                                                 //if a string from the Atlas Scientific product has been received in its entirety
       Serial.print(sensorstring + "\n");                                             //use the hardware serial port to send that data to the PC
       sensorstring = "";                                                      //clear the string:
       sensor_stringcomplete = false;                                          //reset the flag used to tell if we have received a completed string from the Atlas Scientific product
Thanks for any help!
Separate the numbers and then use atoi()
http://www.cplusplus.com/reference/cstdlib/atoi/
