how to stoop serial spaming
hi guys how do you print once to serial only when changing states
i think i need if "this" is "this" and was previously "this" statement but i cant figure out how to write it properly
int lowswitch = 3 ; // pin for low level float switch
int switchup = 0 ; // state of the low level float switch
pinMode(lowswitch,INPUT_PULLUP); // set pin as input with internal pull up
 int switchup = digitalRead(lowswitch); //read the state of the float switch
 // print out the value you read:
    if (!switchup) {
        switchup = 1;
        Serial.print("low");
    } else if(switchup) {
        switchup = 0;
        Serial.print("high");
right now its flooding my serial with either low or high and i just want it to print if it was low and it changed to high or viceversa
Have a look at the "State Change" example in the IDE. It's pretty well explained there but if you still don't understand google it and there are more than a few writeups that explain it in more detail.
Imagine you have a boolean variable called switchStateChanged then you printing could be based on that
if (switchStateChanged == true) {
   Serial.print......
I will leave it as a homework exercise to figure out how to set the value of switchStateChanged
...R
c0ryp1: i think i need if "this" is "this" and was previously "this" statement but i cant figure out how to write it properly
The answer lies in... i think i need if "this" is "this" and was previously "[u]that[/u]"
It is if this time is not equal to last time. You have to remember last time in a variable.
if(switchup != lastSwitchup) { Serial.print("change ");}
lastSwitchup = switchup;
The lastSwitchup should be either a global variable or a static one.
