Hello all,
I am using a PS3 controller with a usb host shield to communicate with an Uno R3. I have two continuous servos connected to the uno that are controlled with the joysticks on the PS3 controller.
These two servos will be used to move a small car.
The issue is the servo continuously running while the the joystick input is at the "90" position. The joysticks are using the map function in the PS3BT library, and are continuously outputting a position while there is power to the Uno.
What I am trying to do is create a dead zone that is 10 percent above and below the 90 position to prevent the servos from slowly moving while there is no joystick input.
I tried to set up an if statement that used the servo.detach() function but it stopped the joystick input all together
Thanks in advance, I hope my question makes sense. I'm new, go easy.
#include <SPI.h>
#include <PS3BT.h> //Three libraries must be included for a PS3 controller with
// an arduino UNO board, SPI, PS3BT, and Servo.
#include <Servo.h>
USB Usb;
BTD Btd(&Usb);
PS3BT PS3(&Btd);
const int buttonInterval = 8000; // number of millisecs between button readings
unsigned long previousButtonMillis = 0; // time when button press last checked
unsigned long currentMillis = 0;
Servo Drservo1; //5 instances must be created for the 5 servos used.
Servo Drservo2; //Each Servo will be used independently except for the two
//drive servos (Drservo1, and Drservo2).
Servo Gripservo;
Servo Craneservo;
Servo Extenderservo;
int DrservoPin1 = 5;
int DrservoPin2 = 3;
if (Usb.Init() == -1) {
Serial.print(F("\r\nOSC did not start")); //This line lets the user know a connection was not made to the USB
//host shield
while (1); //This pauses the code so the problem can be solved
Serial.print(F("\r\nPS3 Connection Made")); //This line lets the user know a connection was made to the controller.
Drservo1.attach(5); //Assigning each servo to it's respective pin
Drservo2.attach(3);
Gripservo.attach(6);
Craneservo.attach(7);
Extenderservo.attach(8);
Usb.Task();
if (PS3.PS3Connected || PS3.PS3NavigationConnected) {
Drservo1.writeMicroseconds(map(PS3.getAnalogHat(RightHatY), 0, 255, 1410, 2210)); // These map functions changes the joystick position from the controller
// to a speed and direction for the servo.
Drservo2.writeMicroseconds(map(PS3.getAnalogHat(LeftHatY), 0, 255, 1410, 2210));
Serial.println(map(PS3.getAnalogHat(RightHatY), 0, 255, 1410, 2210));
Serial.println(map(PS3.getAnalogHat(LeftHatY), 0, 255, 1410, 2210));
if (PS3.getAnalogHat(RightHatY) >=20 && PS3.getAnalogHat(RightHatY) <= 235){
//Drservo1.detach();
digitalWrite(DrservoPin1, LOW);
// if (PS3.getAnalogHat(LeftHatY) >=20 && PS3.getAnalogHat(LeftHatY) <= 235){
// Drservo2.detach();
// digitalWrite(DrservoPin2, LOW);
MEGR_PS3_code.ino (4.21 KB)
