How to stop a macro
Hello, I am coding a macro. In short, the macro presses the 9w0w keys on the keyboard. But when I stop pressing the switch, it does not finish the loop. In other words, 9w0w is written like this every time. What should happen is that as long as I keep it pressed, it will be 9w0w9w0w9w0w, but when I stop pressing it, it may end like 9w0. Can you help me with this?
My Codes :
#include <Keyboard.h>
const int footSwitchPin = A0;
const int threshold = 512;
  pinMode(footSwitchPin, INPUT);
  Keyboard.begin();
  int footSwitchState = analogRead(footSwitchPin);
  if (footSwitchState > threshold) {
    Keyboard.press('9');
    delay(435);
    Keyboard.release('9');
    if (analogRead(footSwitchPin) <= threshold) {
      Keyboard.releaseAll();
      return;
    Keyboard.press('w');
    delay(30);
    Keyboard.release('w');
      return;
    Keyboard.press('0');
    delay(410);
    Keyboard.release('0');
      return;
    delay(30);
      return;
    delay(435);
      return;
  • How can this happen ? :thinking:
  • And of course this will be rock solid. :woozy_face:
  • Awe, didn’t read this delay(435); must have been the 435 number that I ignored.
    I trained my brain (what’s left of it) to ignore delay(. . .)
Yes, I'm new to this. So I'm trying to learn.
I missed what you mentioned because I was struggling with the problem so much. I updated my code. I still have the problem. The switch should work when pressed and stay where it is when I release it.
  Keyboard.begin();
    delay(435);
    delay(30);
    delay(410);
    delay(30);
@Delta_G
@Delta_G
  • Wires need soldering
  • Use pinMode(footSwitchPin, INPUT_PULLUP);
  • As mentioned by @Delta_G use digitalREAD
But everything works on the hardware side. When I run the codes I wrote above, when I press the switch, it writes 9w0w to the screen. But when I take my foot off the switch, it completes the loop. I want it to stop as soon as I take my foot off.
@Delta_G @LarryD
It was already working as I said. But I uploaded new codes to it and I am experiencing the problem I mentioned with these codes.
@Delta_G @LarryD
  • If this is a dry N.O. contact, wire as S3 below.
    Press should give LOW, release gives HIGH.
Thank you. I thought about what you said and now it works without any problems. When I press it, the 9w0w macro works and when I take my foot off it stops. (So it doesn't force the loop to complete.)
My Last Code :
const int threshold = LOW;
  Keyboard.begin();
  int footSwitchState = digitalRead(footSwitchPin);
  if (footSwitchState == HIGH) {
    delay(435);
    if (digitalRead(footSwitchPin) == LOW) {
      return;
    delay(30);
      return;
    delay(410);
      return;
    delay(30);
      return;
