How to stop and listen for button press in Setup
Hello I'm new to Arduino and i was wondering how to listen for button press in Setup and after button press start loop. Can anyone help me ???
Is there any reason you can't wait for the button press in the main loop?
Yeah Because i am going to put Arduino on a model rocket so i will have to make my rocket to start a countdown a single time and then ignite engine and in the loop there is a sensors that monitor all data
Blackfin:
Blackfin:
I'll just leave this here for you to consider.
const int pinButton = 9;
const int pinFireEngine = 10;
#define WAIT_FOR_BUTTON     0
#define COUNTDOWN           1
#define LAUNCH              2
#define READ_SENSORS        3
#define LANDING             4
    pinMode( pinButton, INPUT_PULLUP );
    digitalWrite( pinFireEngine, LOW );
    pinMode( pinFireEngine, OUTPUT );
}//setup
    LaunchSequence();
}//loop
void LaunchSequence( void )
    static byte
        stateLaunch = WAIT_FOR_BUTTON;
    static int
        nCount;
    static unsigned long
        timeCountdown;
    unsigned long
        timeNow;
    switch( stateLaunch )
        case    WAIT_FOR_BUTTON:
            if( digitalRead(pinButton) == LOW )
                timeCountdown = millis();
                nCount = 10;
                stateLaunch = COUNTDOWN;
            }//if
        case    COUNTDOWN:
            //if you want to transmit a 10-9-8...
            //countdown, this is okay
            //you could also simply set timCountdown
            //to 10000 and wait for that to elapse
            timeNow = millis();
            if( (timeNow - timeCountdown) >= 1000 )
                nCount--;
                timeCountdown = timeNow;
                if( nCount == 0 )
                    stateLaunch = LAUNCH;
            }//if
        case    LAUNCH:
            //start the engine and launch
            digitalWrite( pinFireEngine, HIGH );
            stateLaunch = READ_SENSORS;
        case    READ_SENSORS:
            //read and log (or whatever) your sensors
            if( done sensing )
                stateLaunch = LANDING;
        case    LANDING:
            //do nothing. Flight is over
    }//switch
}//LaunchSequence
Thanks everyone :slight_smile: :slight_smile: :slight_smile:
This simple code in setup() will do what you want (if I understand the requirement)
while( digitalRead( startButtonPin ) == HIGH ) { // assumes it will be LOW when pressed
...R
Robin2:
...R
thanks
