Hi Katerina.
Maybe i can help with GoBetwino.
Important stuff with GoBetwino is:
Configure serial port in the settings menu, make sure you are using the correct serial port, and the same Baud rate as setup in your Arduino code.
Do not use GoBetwino and the Arduino IDE serial monitor at the same time, this won't work.
Read the "How to use sample code" document. It explains how to use the XL sample. Try to get this code to work first, this will give you a good starting point for using GoBetwino with your own project.
Feel free to ask any questions in this thread, i will follw it.
EDIT:
When sending data to Excel from Arduino, with GoBetwino try not to send data too fast / frequently, GoBewtino and Excel needs a little time to handle the data.
