Hi, So I am trying to create a project where three buttons are pressed to change states of LEDs and one is the 'off' button but I want to make it so while the LEDs are going on with the state I can push the button to change it to another state but the LEDs don't change states when I press another state button but instead, it doesn't even happen when i press it though.
Here's the script.
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 7;// the number of the pushbutton pin
const int buttonPin1 = 8;
const int buttonPin2 = 9;
// variables will change:
int buttonState = 0;
int buttonState1 = 0;
int buttonState2 = 0;
bool isRunning = true;
//led pins here.
pinMode(1, OUTPUT);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
//button pins here.
pinMode(buttonPin, INPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
//functions here.
void ledControl_(int Times, int delayTime){
if(isRunning == true){
for (int x = 0 ; x < Times ;x++ )
digitalWrite (1, HIGH);
digitalWrite (2, HIGH);
digitalWrite (3, HIGH);
digitalWrite (4, HIGH);
digitalWrite (5, HIGH);
digitalWrite (6, HIGH);
delay(delayTime);
digitalWrite (1, LOW);
digitalWrite (2, LOW);
digitalWrite (3, LOW);
digitalWrite (4, LOW);
digitalWrite (5, LOW);
digitalWrite (6, LOW);
delay(delayTime);
void ledControl_1(int Null, int delayTime){
for (int x = 0 ; x < 20 ;x++ )
if(isRunning == false){
delay(delayTime);
delay(delayTime);
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
buttonState1 = digitalRead(buttonPin1);
buttonState2 = digitalRead(buttonPin2);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if(buttonState == HIGH){
ledControl_(20, 100);
delay(50);
}else if(buttonState1 == HIGH){
ledControl_1(0,100);
}else if(buttonState2 == HIGH){
isRunning = false;
delay(50);
(Code tags added by Moderator)
