How to stop EMI from a pwm-fan
Paul_KD7HB:
No tricks at all are involved. Have you installed bypass capacitors on the leads to the fan and on the leads picking up the interference?
Paul
I have some capacitors here, 50V 470 UF
Can i use one on the plus/ground of the fan? Which wire of the capacitor is the plus-side? The long or short one?
The lawmmower motor doesn't work when i use the fan, i guess the EMI is on the pwm-lead to control it but it might be on the power leads...again, how do i place the capacitor on the powerleads? Same as the fan?
The high amp leads to lawnmower and drivemotors are further away but not twisted, should i twist them or even cover with some shielding? I want to get rid of all the EMI if possible because i'll install many more sensors/camera's etc.
