When I start the IDE (1.8.19) I get a prompt "Install this package to use your Arduino Tian board."
How do I remove it?
I do not want to install the package as will never use it & try to keep bloat to minimum on my system.
How do I remove it?
Hi @cday-nz. Unfortunately it seems the poor decision was made to associate the VID/PID pair of the Silicon Labs CP2105 USB to serial adapter chip with the Arduino Tian board definition. I guess you must have a device with a CP2105 on it attached to your computer.
The only possible solution I can think of is to find a way to configure your firewall or other network settings to block the Arduino IDE from "phoning home". The Arduino IDE sends an API request for each of the VID/PID pairs of the USB devices that are connected to your computer. Then if the response indicates this VID/PID is of an official Arduino board, the IDE knows to offer you the installation of the appropriate boards platform.
In this case, the request is this URL:
https://builder.arduino.cc/v3/boards/byVidPid/0x10C4/0xEA70
and the response:
{"architecture":"samd","fqbn":"arduino:samd:tian_cons","href":"/v3/boards/arduino:samd:tian_cons","id":"tian_cons","name":"Arduino Tian (MIPS Console port)","package":"arduino","plan":"create-free"}
OK that makes sense. I am an amateur radio operator & all the latest Yaesu transceivers use CP2105 for CAT control - FTdx10, FTdx101, FT991a. In my case the FTdx10 is always connected to my PC. I'm sure there are a heck of allot of other devices out there using this chip also.
Thanks for the suggestion to block URL via firewall. I'll look into it.
Cheers
..just confirming blocking
builder.arduino.cc
..worked
Excellent work on getting the solution working!
Most Arduino boards have a unique VID/PID pair owned by Arduino and dedicated specifically to that product. For those, you would not ever get an incorrect platform installation offer.
The Tian board is different in that a general purpose USB to serial adapter chip was chosen, using the VID/PID pair provided by Silicon Labs. I submitted a request that the association be removed for this specific board:
