How to stop interference is camera cable?
Don’t know if this is in the correct place.
I am helping a friend with an experiment recording video and playing sound under water in a cage. This is controlled by an Arduino on a floating platform at the surface. The surface box also contains a battery and dvr.
This is the camera used:
https://www.ebay.co.uk/itm/30M-HD-1200TVL-CCTV-Camera-Underwater-Fish-Finder-For-Ice-Sea-River-Fishing-G6Q5/263590542681?hash=item3d5f387d59:g:ndgAAOSwMalaxvPr
The speaker cable is two core flex.
The camera and speaker cable are taped together and cable tied to rope on cage.
Problem is when speaker is on the picture from the camera is mostly just noise. When speaker is off the video is ok.
Can I shield either the speaker or camera cable without replacing them? Would a shield connect to battery negative?
Is there any other way of removing interference from video signal?
I have added two pictures to show my problem. The bad one is with speaker on.
Hope someone can help.
Thanks,
Damien.
You have a class-D audio amp driving the speaker? Change to a linear amp will fix it.
I do. What class is linear?
Seedler:
Most linear is class A. Next is some version of class B.
Paul
Once the noise is on the picture there is not much you can do. Best not let it get on in the first place.
However it does not look like noise to me. Noise is speckled, that looks like you have wiped out the sync pulses. It could be a power supply issue, look at the video signal on a scope.
I don't have a scope. Would this be a case of connecting neutrals?
Would shielded cable solve this? Would I need to shield speaker cable or video cable, or both? I don't want to have to rewire if I don't have to.
I'll give the linear amp a go.
Thanks.
Grounds yes but neutrals are things used in mains wiring and you should not connect them together.
It would help but is not a grantee cure.
Both would be better.
That is a very good first step, to drastically reduced the interference you are generating in the first place.
Grumpy_Mike:
I agree with you.
Locate source of the problem.
Take everything from the water - any changes ?
Use separate power supply for camera - any changes ?
I have to keep speaker in the water because it cant be powered dry, but I will try separate power supply.
What does wiped out sync pulses mean?
Does anyone know of a class-A 30watt mono board that runs off 12vdc. Everything I find runs on 12vac.
Thanks,
Damien.
Wipe out means destroys.
Sync pulses are the bit of a composite video signal that tells the receiving TV that each line and each frame has started.
That is because the amplifier is making a split supply with the input voltage. That implies you are not looking at class A amplifiers but class B.
put it in a bucket of water
You may have interferences from speaker wires,they act as transmitting antenna, water can increase the interferences ........
Try for speaker twisted pair cable or coax cable
Sync pulses
http://www.ni.com/white-paper/3020/en/
You don't need to change amplifier, you need locate the source of interferences.
Problem is the speaker belongs to university. It came pre-wired with 20 meters of two core flex. I don’t want to rewrite it with twisted pair or coaxial if I don’t have to.
I will put speaker in water tomorrow and start testing
If you don't want to touch the wires you have only 1 option which may work - battery for camera.
What happens when camera is not in the water ?
Mike Ted, yous were rite, power supply. Tried separate battery for dvr and camera and picture stayed clear, even with sound on.
I tried powering dvr separately and camera separately with varying results, but the best result is dvr and camera on the same battery and Arduino and speaker on another battery.
So my question now is, how do I run this off the same battery? My setup is for a single 12v battery. Can I filter the power to the dvr/camera somehow, or make them think they are on a different battery?
Thanks for all your help,
Damien.
What is the voltage required by each toy, I assume Arduino 5V, Camera ?, Amplifier ?
And what kind of power supply you are using.
12v to Arduino uno that it is regulating down to 5v itself.
12v relays. Powered by 12v but controlled by 5v Arduino signal.
12v to amplifier/speaker switched through relay
12v to camera and dvr switched through relay.
They are all running off a 12v 40Ah AGM battery.
Thanks.
Seedler:
Thanks.
Huge capacitor on amplifier power terminals 5000 - 10 000 uF
5V Voltage regulator for arduino, two 1000uF capacitors, input output.
Camera may work at 9V; 9V Voltage regulator and two capacitors as above.
Then you have seperated power supply for each device.
So is that a huge capacitor on 12v power input of amplifier?
Is the unos onboard 5v regulator not ok, and does it not have smoothing capacitors on input and output?
Camera and dvr don't seem to want to work at 9v, so it will have to be 12v. What to I do here?
Do I need to worry about the relay board?
Seedler:
So is that a huge capacitor on 12v power input of amplifier? - The place where you connect wires from battery
Is the unos onboard 5v regulator not ok, and does it not have smoothing capacitors on input and output? - Arduino should be powered by 5V not 12V, voltage regulator on it is for creating 3.3V
Camera and dvr don’t seem to want to work at 9v, so it will have to be 12v. What to I do here? - Dont touch for now and look what happens when you do capacitor and 5V regulator
Do I need to worry about the relay board? - Dont touch for now and look what happens when you do capacitor and 5V regulator
