How to stop process on receiver HC-12 when the sender HC-12's power go offline ?
I want the led to turn off on the receiver when the power goes offline on the sender HC-12.
Code for the sender :
void loop{
    String st = "hello";
    HC12.print(st + 'A');  // send st to the receiver
    delay(100);
Code for the receiver :
void loop{
    while(HC12.available()){
        digitalWrite(led, 1);
        String st = HC12.readStringUntil('A');
        Serial.println("receive = " + st);
        delay(10);
Could anyone help me, please?
I recommend 2 extensions:
  • At the receiver a timeout has to be coded, which recognises after about 200 ms, that the transmitter does not do any more.
  • If the transmitter is interrupted during a message, the command "readStringUntil (...)" must be terminated by timeout too. For this there is the command "Serial.setTimeout (...).
long lTimeout;	// Holds the millis() for timeout calc.
	HC12.setTimeout(200);	// Timeout for active readStringUntil(...)
	lTimeout = millis();	// Initial value for timeout in while(...)
void loop{
    delay(10);
		lTimeout = millis();	// Timeout stating new
	if ((millis() - lTimeout) > 200)	// Set timeout to 200 ms
		digitalWrite(led,0);	// Timeout detected -> LED off
Thank you so much, man. Why the Tx led on receiver keep blinking? Why not Rx led?
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. This can happen after the program has been running perfectly for some time. Just use cstrings - char arrays terminated with ‘\0’ (NULL).
Serial.readstring() is a blocking function. Have a look at the examples in Serial Input Basics - simple reliable, non-blocking ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
The technique in the 3rd example will be the most reliable. It is what I use for Arduino to Arduino and Arduino to PC communication.
You can send data in a compatible format with code like this (or the equivalent in any other programming language)
Serial.print('<'); // start marker
Serial.print(value1);
Serial.print(','); // comma separator
Serial.print(value2);
Serial.println('>'); // end marker
Everytime that a new message is received save the value of millis() - something like
lastMessageTime = millis();
and then your code can have a check like this to see if the time between messages was too long
if (millis() - lastMessageTime >= allowedTime) {
   // message has failed, do something
…R
