I don't know if this is the correct place to post this, or if I should be in etextiles, but since I am using a light sensor, I figured this would be as good a place as any.
I am using a protosnap lilypad with the light sensor and buzzer that is included on the board. I have written my code so that if any light is detected the buzzer starts to play the Star Wars theme on the buzzer.
So far, it's working fine, but I was wondering, is there a way to get it to stop playing the music when the light sensor is covered? What I mean is that if I cover the light sensor, it plays through the current song and then stops, but I want it to stop in the middle of the song as soon as the light is gone.
I will paste my code below (I am a beginner, I know there are better ways to handle the buzzer code, but I didn't understand all of the other code I found, so I made this work (I'm not a musician so trying to mathematically figure out tempo etc... didn't make much sense to me). Any help would be appreciated, let me know if you need any other info from me, Thanks!
#include "pitches.h"
int sensorPin = A6; // Light Sensor connected to A6
int sensorValue; // variable to store the value coming from the sensor
int TestLED = A3; // LED connected to analog pin A3
int buzzer = 7; // Piezo Buzzer connected to Pin 7
void setup() // run once, when the sketch starts
Serial.begin(9600); // initialize the serial port
pinMode(A6, INPUT); // sets analog pin A6 to be an input
pinMode(TestLED, OUTPUT); // sets analog pin 3 to be an output
void loop() // run over and over again
sensorValue = analogRead(sensorPin); // read the value from the sensor
Serial.println(sensorValue); // send that value to the computer
if (sensorValue < 10000 && sensorValue >= 100) //Light Detected, The higher the second sensorValue, the less sensitive it is to light.
digitalWrite(TestLED, HIGH); //turns on led connected to pin 3
// Play the Star Wars Theme, using pitches.h include, the parenthesese have the Buzzer pin, note, and duration
tone(7, NOTE_F4, 200);
delay(200);
delay(200);
delay(200);
tone(7, NOTE_AS4, 1200);
delay(1200);
tone(7, NOTE_F5, 600);
delay(600);
tone(7, NOTE_DS5, 200);
delay(200);
tone(7, NOTE_D5, 200);
delay(200);
tone(7, NOTE_C5, 200);
delay(200);
tone(7, NOTE_AS5, 1200);
delay(1200);
delay(600);
delay(200);
delay(200);
delay(200);
delay(1200);
delay(600);
delay(200);
delay(200);
delay(200);
tone(7, NOTE_C5, 900);
delay(1200);
noTone(7);
else //No Light Detected
digitalWrite(TestLED, LOW);
And the pitches.h code I included has the frequency all figured out for the notes to make it easier to write the music portion. I will include it here too just in case that helps:
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 41
#define NOTE_F1 44
#define NOTE_FS1 46
#define NOTE_G1 49
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 104
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 147
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 247
#define NOTE_C4 262
#define NOTE_CS4 277
#define NOTE_D4 294
#define NOTE_DS4 311
#define NOTE_E4 330
#define NOTE_F4 349
#define NOTE_FS4 370
#define NOTE_G4 392
#define NOTE_GS4 415
#define NOTE_A4 440
#define NOTE_AS4 466
#define NOTE_B4 494
#define NOTE_C5 523
#define NOTE_CS5 554
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 740
#define NOTE_G5 784
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1047
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1245
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1480
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2349
#define NOTE_DS7 2489
#define NOTE_E7 2637
#define NOTE_F7 2794
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 4186
#define NOTE_CS8 4435
#define NOTE_D8 4699
#define NOTE_DS8 4978
