How to stop repeat? basic questiom
How do i get this to only say button pushed once when switch pin is low and only print the tim ewhen it retuns to low?
const int switchPin = 2; // the number of the input pin
long startTime; // store starting time here
long duration; // variable to store how long the timer has been running
float secduration; // variable to store the duration in seconds
pinMode(switchPin, INPUT_PULLUP);
if(digitalRead(switchPin) == LOW){
startTime = millis();
Serial.println("Button Pushed");
while(switchPin == LOW){
delay(1);
if(digitalRead(switchPin) != LOW){
duration = (millis() - startTime);
secduration = (float)duration/1000;
Serial.print("Button released after ");
Serial.print(secduration);
Serial.println(" seconds");
consider
byte butLst;
    butLst = digitalRead (switchPin);
    unsigned long msec = millis ();
    byte          but  = digitalRead(switchPin);
    if (butLst != but)  {
        if (LOW == but) {
            startTime = msec;
        else {
            secduration = (msec - startTime) / 1000.;
        butLst = but;
        delay (10);     // debounce
Take a look at the state change detection example and the state change for active low switches tutorials. They will allow you to detect when the switch becomes pressed (the transition) as opposed to when it is pressed (the level).
Read the forum guidelines. Post your test code in code tags. Use the IDE autoformat tool (ctrl-t or Tools, Auto Format) to indent the code for readability before posting code.
Try this way
  if (digitalRead(switchPin) == LOW)
    while (digitalRead(switchPin) == LOW){}
    secduration = (float)duration / 1000;
Thank you so much! worked perfectly
