How to Stop repeating count for analog signal
Part of the code I used
Count = 1;
CountUP()
Val = analogRead(X);
delay(200);
if (Val >= 200 && Val <=250 && Count <10)
Count = Count =+1;
I have two values 400-450 and 200-250
When the Value (Val) is between 200-250
I want only to count once in 200-250 untill i change to 400-450 value and again change to 200- 250
but this code counts continuously from 1 to 10 while in 200-250
Any idea how to stop this?
Try this:
Count = 1;
  bool flag = false;
  CountUP()
    delay(200);
    if (Val >= 200 && Val <= 250 && Count < 10 && flag == false; )
      flag = true;
      Count = Count = +1;
      if (Val < 200 !! Val > 250 ){
        flag = false;
Let me try this now.
ops there a error, sorry
try this:
Count = 1;
  bool flag = false;
  CountUP()
    delay(200);
    if (Val >= 200 && Val <= 250 && Count < 10 && flag == false )
      flag = true;
      Count = Count = +1;
      if (Val < 200 || Val > 250 ){
        flag = false;
There is another error, bus this is your error:
Count = Count = +1; error
Count = Count +1; Right
or
Count++;
Complete test:
float Val = 0;
int Count = 1;
  CountUP();
bool flag = false;
void CountUP()
  Serial.println(Count);
  Serial.println(Val);
  Val = analogRead(0);
  delay(200);
    flag = true;
    Count++;
  if (Val < 200 || Val > 250 ) {
    flag = false;
Hey it worked :face_blowing_a_kiss:
But a problem, i used the same code for count down , when i use it, then it again repeat the counter ( for both up and down,
Count down value is 650 - 700
Normal position 400-450 nothing happens
Count up 200-250
Count down 650-700
Your code works for count up,
When use same code for count down,
Repeat starts again
Any idea
Post your complet code.
