How to store a starting number that my current number can reset to
// Libraries for OLED
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "modified_font.h"
// Define parameters
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET     -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, -1);
// Define Variables
int upPin = 8;
int dnPin = 7;
int shotPin = 4;
const int selPin = 5;
bool dissable = false;
int strtValue = 0;
char msg1[] = "Set your ammo count:";
char msg2[] = "READY";
int buttonState;
int lastButtonState = LOW;//when using INPUT_PULLUP the pin values are inversed, in this case LOW will mean HIGH etc.
unsigned long lastDebounceTime = 10;
unsigned long debounceDelay2 = 2000;
unsigned long debounceDelay = 1;
void setup()// intialize screen
    display.begin (SSD1306_SWITCHCAPVCC, 0x3C);
    pinMode(upPin, INPUT_PULLUP);
    pinMode(dnPin, INPUT_PULLUP);
    pinMode(selPin, INPUT_PULLUP);
    pinMode(shotPin, INPUT_PULLUP);
    display.clearDisplay();
    display.setTextSize(1);
    display.setTextColor(WHITE);
    display.setCursor(0,0);
    display.println(msg1);
void loop() // call variables and display to screen
    int i = strtValue;
    if(strtValue <= 0)
        strtValue = 0;
    display.drawRoundRect(7, 53, 114, 7, 3, WHITE);
    display.fillRoundRect(7, 53, i, 7, 3, WHITE);
    display.drawRoundRect(1, 16, 127, 48, 4, WHITE);
    increaseParameter();
    decreaseParameter();
    selectParameter();
    shotParameter();
    //display.setFont(&Orbitron_Medium_12); display.setTextSize(4);
    display.setCursor(42,16);
    display.println(strtValue);
    display.display();
void increaseParameter()
    int reading = digitalRead(upPin);
      if (reading != lastButtonState)
      delay(30);
          lastDebounceTime = millis();
      if((millis() - lastDebounceTime) < debounceDelay)
            if(reading != buttonState)
                buttonState = reading;
                if(buttonState == LOW)
                  strtValue++;
      lastButtonState = reading;
void decreaseParameter()
    int dnReading = digitalRead(dnPin);
      if (dnReading != lastButtonState)
      delay(30);
          if(dnReading != buttonState)
              buttonState = dnReading;
                strtValue--;
      lastButtonState = dnReading;
void selectParameter()
    int selReading = digitalRead(selPin);
      if (selReading != lastButtonState)
      delay(30);
          if(selReading != buttonState)
              buttonState = selReading;
              if(buttonState == LOW)//button pressed
                upPin = dissable;
                dnPin = dissable;
                display.setTextSize(2);
                display.setCursor(42,0);
                display.println(msg2);
                display.setCursor(40,16);
        lastButtonState = selReading;
void shotParameter()
    int shotReading = digitalRead(shotPin);
      if (shotReading != lastButtonState)
      delay(100);
          if(shotReading != buttonState)
              buttonState = shotReading;
                strtValue--;
                delay(1);
      lastButtonState = shotReading;
Hello everyone this is my first arduino uno project and overall introduction to coding as a whole so my experience is limited. Im currently designing a digital ammo counter using a 128 x 64 OLED display with the Adafruit_ssd1306 library. Right now im trying to figure out how to detect when a button is pressed for longer than a second and upon release of said button for that to reset my starting number to a specified max number which is selected by the user on startup. I have my increase, decrease, select, reset and bullet shot functions all working but now i'm trying to get the selected number to reset back to max ammo. Any info/ suggestions are much appreciated
Looking at the code I will take a SWAG: When you start save the max ammo in a variable, then when reseting copy that variable to the counting variable. UsedAmmo=StartAmmo would work.
Which button needs to be held for more than 1 second? To accomplish this, you will have to record the time [millis()] when said button is first pressed and then calculate elapsed time when said button is released.
