How to store distance data in array and calculate average of data from ultrasonic sensor
I have tried this below code to get data from ultrasonic sensor of a particular object distance and store it in a array to calculate it average distance.
 #define trigPin 5
#define echoPin 2
long duration=0;
long distance=0;
long RightSensor=0;
int timeR=0;
int sum=0;
int my_array[5];
  Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
  for (int i=0;i<5;i++){
   RightSensor = dist();
   if(RightSensor<15){
    my_array[i] = RightSensor;
     Serial.print("Distance From the Hazard Point = ");
Serial.println(RightSensor);
long dist(){
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration/58.2;
  return(distance);
And? Did you get results? Were they correct? Were the results what you actually measured?
the data i was getting it prints 5 times but i want to store of 5 data in array.
Try:
#define trigPin 5
#define echoPin 2
long duration = 0;
long distance = 0;
long RightSensor = 0;
int timeR = 0;
int sum = 0;
int my_array[5];
  // acquire and store the readings
  for (int i = 0; i < 5; i++) {
  // print the readings
    Serial.println(my_array[i]);
long dist() {
  distance = duration / 58.2;
  return (distance);
I would check to see what range of distances can be returned by the ultrasonic sensor. Your dist() function returns a LONG but your my_array is only an INT.
What is the significance of the reading being less than 15?
You seem to be looping 25 times - why?
Rolling average:
Moving average filter - Using Arduino / Sensors - Arduino Forum
i want to store data for finite range . then storing it in a array suppose 5 data has store in this finite location then i will sum this and give a average distance of that 5 data.
By the way thank you so much
Is the data correct? If not fix that first.
