How to store numbers in Arduino?
I have written this to an Arduino.
Click here to view, I couldn’t embed it
What I want to do is: - connect to serial (check) - collect 2 variables to add/subtract/multiply/divide later (check) - collect a variable to decide what to do with them 1-add, 2-subtract, etc. (check) - redirect the script to do the required operation (later) - print the result to serial (check)
The problem is, when I enter 1 and 1 and 1(whatever, the third one doesn’t count now) and I get 98 as a result. Any help? Maybe the variables are wrong?
I'll embed it for you
char incomingbytea;
char incomingbyteb;
char incomingop;
char result;
void loop(){
	incomingbytea = 0;
	incomingbyteb = 0;
	incomingop = 0;
	result = 0;
	bytea:
  	if (Serial.available() > 0) {
    incomingbytea = Serial.read();
  	Serial.println("1ok");
  	Serial.println(incomingbytea);
  	goto byteb;
  	goto bytea;
  	byteb:
  	incomingbyteb = Serial.read();
  	Serial.println("2ok");
  	Serial.println(incomingbyteb);
  	goto op;
  	goto byteb;
  	op:
  	incomingop = Serial.read();
    Serial.println("opok");
    Serial.println(incomingop);
    goto oper;
  	goto op;
  	oper:
  result = incomingbytea + incomingbyteb;
  Serial.println(result);
98 seems like an interesting number, but why?
Well let us take a look at this table, and I want you to try and figure it out.
I didn't know you can add type char variables together and expect an integer result.
varkokonyi:
Maybe you don't know the difference between a 'number', 'character' and 'ASCII code'?
Look at this ASCII table:
The character '1' has the ASCII-code '49'.
So if you get 98 as the result when adding '1'+'1', you don't add the numbers, but you add the ASCII-codes of the characters '1' and '1', which is 49+49 and the result is 98.
You're using goto statements. They have been scorned as a source of trouble for about 40 years now. So how about fixing that too?
Ps991:
@jurs
aarg:
OK, I want to get better. What should I use instead of them?
Ps991:
char incomingbytea;
char incomingbyteb;
char incomingop;
char result;
void loop(){
incomingbytea = 0;
incomingbyteb = 0;
incomingop = 0;
result = 0;
bytea:
  goto byteb;
  goto bytea;
  byteb:
  goto op;
  goto byteb;
  op:
    goto oper;
  goto op;
  oper:
![|500x341](http://www.asciitable.com/index/asciifull.gif)
Ok, I think I see what you mean. Thanks
If you have:
label:
    // some code
    if(someCondition)
       goto label;
that is more conventionally done using:
   while(someCondition)
      // some code
Other (mis)uses of goto can be similarly replaced by thinking positively (do this if) instead of negatively (that didn't do what I wanted, so go back and try again).
While statements and return statements can eliminate 90+% of goto statements.
If you need help with a specific example, we're here to help.
