How to Store the results from a Ping Sensor in a variable
I need your suggestions and help with my Ping Sensor. I have an Arduino Uno with a Parallax Ping sensor and a motor attatched to the motor.
My ping sensor is set to to start the motor when the nearest object is <= 10cm. That works fine. Now, I'd like the motor to start only if the values of the sensor are progressing in a decreasing manner i.e 15, 14, 13, 12, 11, 10 but do nothing if the values of distance are progressing in a increasing manner.
I was thinking if I stored the last 3 pings as variables and using an if/else statement but I don't know how to implement it.
How can I implement this, or if you have any other suggestion, please help me. Thank you
Here is what i have so far:
/* Ping))) Sensor
  This sketch reads a PING))) ultrasonic rangefinder and returns the
  distance to the closest object in range. To do this, it sends a pulse
  to the sensor to initiate a reading, then listens for a pulse
  to return.  The length of the returning pulse is proportional to
  the distance of the object from the sensor.
  The circuit:
   * +V connection of the PING))) attached to +5V
   * GND connection of the PING))) attached to ground
   * SIG connection of the PING))) attached to digital pin 7
  http://www.arduino.cc/en/Tutorial/Ping
  created 3 Nov 2008
  by David A. Mellis
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
// this constant won't change.  It's the pin number
// of the sensor's output:
const int pingPin = 7;
const int motorPin = 9;
//Yomis code
//int pings[3] = {-1,-1,-1};
//int i;
//bool Increasing(int p1, int p2, int p3)
//  if(p1 < p2 && p2 < p3){
//    return true;
//bool Decreasing(int p1, int p2, int p3)
//  if(p1 > p2 && p2 > p3){
//    return true;
//end of yomis code
 // Set up the motor pin to be an output:
 pinMode(motorPin, OUTPUT);
 // initialize serial communication:
 // establish variables for duration of the ping,
 // and the distance result in inches and centimeters:
 long duration, inches, cm;
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 // Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
 pinMode(pingPin, OUTPUT);
 digitalWrite(pingPin, LOW);
 delayMicroseconds(1000);
 digitalWrite(pingPin, HIGH);
 delayMicroseconds(2000);
 // The same pin is used to read the signal from the PING))): a HIGH
 // pulse whose duration is the time (in microseconds) from the sending
 // of the ping to the reception of its echo off of an object.
 pinMode(pingPin, INPUT);
 duration = pulseIn(pingPin, HIGH);
 // convert the time into a distance
 inches = microsecondsToInches(duration);
 cm = microsecondsToCentimeters(duration);
 Serial.print(inches);
 Serial.print("in, ");
 Serial.print(cm);
 Serial.print("cm");
//        //Yomis code
//        if (cm <= 10)
//          Serial.println();
//          Serial.println(pings[0]);
//              Serial.println(pings[1]);
//              Serial.println(pings[2]);
//          if(Increasing(pings[0],pings[1],pings[2]))
//            int Speed1 = 100;  // between 0 (stopped) and 255 (full speed)
//            int Time1 = 3000;  // milliseconds for speed 1
//            analogWrite(motorPin, Speed1);  // turns the motor On
//        else
//          analogWrite(motorPin, LOW);
//        //End of yomis code
 if (cm <= 10) {
   int Speed1 = 150;  // between 0 (stopped) and 255 (full speed)
   int Time1 = 2000;  // milliseconds for speed 1
   int Speed2 = 250;   // between 0 (stopped) and 255 (full speed)
   int Time2 = 3000;  // milliseconds to turn the motor off
   delay(Time1);                   // delay for onTime milliseconds
//    analogWrite(motorPin, Speed2);  // turns the motor Off
//    delay(Time2);                   // delay for offTime milliseconds
 else if (cm > 10) {
   analogWrite(motorPin, LOW);  // turn the motor off
 else {
   Serial.print(cm);
   Serial.print("cm");
   delay(100);
long microsecondsToInches(long microseconds)
 // According to Parallax's datasheet for the PING))), there are
 // 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
 // second).  This gives the distance travelled by the ping, outbound
 // and return, so we divide by 2 to get the distance of the obstacle.m
 // See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
 return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
Can you edit your post and use code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom........ :slight_smile:
As Tom said, use code tags.
But what about this as an idea:
Take distance reading, and take a timestamp.
If time passed since timestamp is more than interval, take a second reading.
subtract first reading from second reading
if its negative, the distance is decreasing ( and the rate is easily worked out if needed )
if its positive, the distance is increasing ( again rate is easily worked out )
okay i just corrected it
