Hello All
This is my first post here and I’m new to the arduino too, so apologies for any rookie errors.
I’m trying to write a program that uses an Arduino Mega, a joystick, LCD display and 3 buttons to automate some outputs.
For example, knock the joystick left it will turn on output x for 3 seconds, then output y for 2 seconds.
Knock it right and it’ll do output z for 3 seconds then output x for 6 seconds etc etc. So I’m using it as 4 way switch, plus the joystick press as a 5th option.
I’m also using the 3 buttons to access a menu system on the LCD. I.e. press left button to access menu, then the iddle button as a “+” and the right button as a “-”. Then the left button as a “Select” to allow me to scroll through and alter the respective timers.
I found this link
about planning a project, and have worked through, looking at a few tutorials and examples. Everything was going well, but now it is saying ‘inputs’ was not declared in this scope’ when I try and upload. Am I trying to put too much into one sketch?
I read somewhere that the function needs declaring before it’s called - but how do I do this when all the functions call each other?
I’m guessing there is a better way to implement all of this?
// Define joystick axes
#define joyX A0
#define joyY A1
//Include library code
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
//Setup joystick button
int joybut=2;
int joybutState = 0;
int joybutState1 = 0;
//Setup menu buttons
int lbut=3;
int lbutState = 0;
int mbut=4;
int mbutState = 0;
int rbut=5;
int rbutState= 0;
//Setup joystick
pinMode(7,OUTPUT);
pinMode(joybut,INPUT);
pinMode(lbut,INPUT);
pinMode(mbut,INPUT);
pinMode(rbut,INPUT);
digitalWrite(joybut, HIGH);
digitalWrite(lbut, HIGH);
digitalWrite(mbut, HIGH);
digitalWrite(rbut, HIGH);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Control System!");
lcd.setCursor(0,1);
menuCheck();
void menuCheck() {
lbutState = digitalRead(lbut);
if (lbutState == LOW) {
lbutState = HIGH;
lcd.setCursor(0,0);
lcd.print("Main Menu ");
lcd.setCursor(0,1);
lcd.print("Exit ");
delay(300);
exitMenu();
else {
inputs();
void exitMenu() {
mbutState = digitalRead(mbut);
rbutState = digitalRead(rbut);
if (rbutState == LOW) {
rbutState = HIGH;
lcd.setCursor(0,1);
lcd.print("Timers ");
delay(300);
timerMenu();
lbutState = HIGH;
lcd.setCursor(0,0);
lcd.print("Control System");
lcd.setCursor(0,1);
delay(300);
inputs();
exitMenu();
void timerMenu() {
rbutState = HIGH;
lcd.setCursor(0,1);
lcd.print("Exit ");
delay(300);
exitMenu();
timerMenu();
void inputs() {
int xValue = analogRead(joyX);
int yValue = analogRead(joyY);
joybutState = digitalRead(joybut);
if (xValue>=500 && yValue<=200)
lcd.print ("LEFT ");
delay (1000);
lcd.print (" ");
if (xValue<=200 && yValue>=500)
lcd.print("UP ");
if (xValue>=1000 && yValue>=500)
lcd.print("DOWN ");
if (xValue>=200 && yValue>=1000)
lcd.print("RIGHT ");
if (xValue>=1000 && yValue>=1000)
Serial.write("oops!");
if (joybutState == LOW)
lcd.print("Joystick click ");
