How to sum up all the value in SD file.
Hi, I would like to sum all the value that I save from text.txt file.
example: Save/text.txt
inside the text is:
1 2 3 3 2 3 2 1...3 2 1 = depending on the number of values i've input ?
#include <SPI.h>
#include <SD.h>
File myFile;
  Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  char c=Serial.read()
    if(c=='H')          //input value
      if(!SD.exists(text.txt))
        myFile = SD.open(text.txt);     //Write .txt file in SD, done.
        if (myFile) {
          myFile.println("2");
          myFile.close();
  if(c=='L')          //input value
      if (myFile) {
        myFile.println("3");
        myFile.close();
  if(c=='S')
    //[i]then sum-up all the values that is input in text.txt[/i]
The basics can be found here:
http://forum.arduino.cc/index.php?topic=158438.0
thank you sir mrburnette :smiley: solved
but then using I2C, i got problem.
seems i can't pass the bufs value of from loop() to void requestEvent() to pass it to master using Wire.h.
  if(s=='H')
     myFile = SD.open("test.txt");
    if (myFile) {
      Serial.println("test.txt:");
      while (myFile.available()) {
        S1 = myFile.parseInt();
        a=a+S1-0;
        Serial.print(a); //it can display the total sum of test.txt value.
      myFile.close();
    sprintf(bufs,"sum:%lu",a); //the value of bufs will be pass for I2C com. but i can't get it.
  a='\0';
 delay(5000);
void requestEvent()
  Wire.write(bufs);
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
int S1;
char i;
int a=0;
Wire.begin(5);
Wire.onReceive(receiveEvent);
Wire.onRequest(requestEvent);
while (!Serial) {
if (!SD.begin(4)) {
return;
randomSeed(analogRead(0));
lcd.print("Initialization done");
delay(2000);
if(s=='H') //from void receiveEvent(int howMany)
if (myFile) {
a=a+S1-0;
Serial.print(S1);
Serial.print(a);
myFile.close();
a='\0';
delay(5000);
while(Wire.available() > 0)
char c = Wire.read();
numbers[i++] = c;
numbers*='\0';*
    if (strcmp (numbers,"A")==0) {
  • s='H'; //pass to void loop()*
    void requestEvent()
  • Wire.write(bufs); // i can't get the bufs value from void loop().*
    it can display the total sum from test.txt file after summing up to Serial monitor but i need to get the value and display to master.
    i can't pass the value from slave to master.
here's my first code, which is not in void loop(). but when i send data "A" from master to trigger,
my problem is it hang and nothing happen. help.
char bufs[70];
int S1;
int a=0;
// SD initialization
//no code here, all the codes are in void receiveEvent(int howMany)
    numbers[i++] = c;
    numbers='\0';
    if (myFile) {
        a=a+S1-0;
        Serial.print(S1);
        Serial.print(a);
      myFile.close();
void requestEvent()
  Wire.write(bufs);
a='\0';
