How to sweep servo motors only once after restart?
Hi I'm trying to make an automatic dosing system for my reef aquarium, i'm gonna use syringes with valves and servos.
Right now I have to do it manually (which is not a big problem but dosing smaller amounts more often is more beneficial for my corals)
I need 4 servos to sweep only limited number of times after being restarted.
I must be able to change the number of sweeps from time to time. (It can be via usb and change in code)
I am gonna use timer switch socket to restart the thing. (I don't want this to be alive all the time - if something goes wrong, and it would dose whole bottles of solutions it could kill my corals)
I am new to arduino, and I don't understand too much programing.
Can someone please send me programming code for this and highlight the values for individual servo to set the number of sweeps after being restarted?
I was able to use servo sweep example, plug everything right and with servo having its own power supply different from the main board.
I am willing share your knowledge and codes with everybody on youtube. (so noone would have to bother you with this again).
Thank you
Dave
