How to switch to an other configuration
Part 1
combination SwitchA SwitchB led1 led2 led3 led4
1 Off Off O X X O
2 On Off X O O O
3 Off On O O O X
4 On On X X X X
Part 2
1 Off Off X O O X
2 On Off O O O X
3 Off On X O O O
4 On On * * * *
O = Low
X = High
  • = blinking led
The program needs to start with part 1 you can press any combination but when you press combination 4 it needs to go too part 2.
In part 2 you can also press any combination but when you press combination 4 it needs to go back to part 1.
The problem is that i cant switch from part 1 to part 2.
I hope you can help me.
_20150627_Examenvraag_Maurice_versie_3.ino (1.94 KB)
Put the code that is now in loop() into a function called loopA() and create a new loop() function that is something like this
   selection = digitalRead(selectionSwitchPin);
   if (selection == HIGH) {
      loopA();
   else {
      loop2();
That is probably a bit too simple - but it will give you the idea.
...R
