how to sync 2 servos on two different pins
i wrote a program in vb.net that sends signals via serial to the following arduino program, first a char to identify which servo to move and second a byte that represents the angle of how much the servo is to move:
int servoPin7=7;
int servoPin8=8;
int pulsee = 0;
int minPulsee = 500;
int maxPulsee  = 2500;
int pulsef = 0;
int minPulsef = 500;
int maxPulsef  = 2500;
long lastPulse = 0;
int refreshTime = 20;
//signal declarations
char id;
int angle=0;
int sigCount=0;
  pinMode(servoPin7,OUTPUT);
  pinMode(servoPin8,OUTPUT);
pulsee=500;
pulsef=500;
  readSignal();
    if (id=='e')
    pulsee = map(angle,0,180,minPulsee,maxPulsee);
 if (id=='f')
    pulsef = map(angle,0,180,minPulsef,maxPulsef);
  update();
void readSignal()
  if(Serial.available())
    if (sigCount==0)
      id=Serial.read();
      sigCount=1;
      Serial.flush();
    else if (sigCount==1)
      angle=Serial.read();
      sigCount=0;
      Serial.flush();
void update()
  if (millis() - lastPulse >= refreshTime)
    digitalWrite(servoPin7, HIGH);
    delayMicroseconds(pulsee);
    digitalWrite(servoPin7, LOW);
 digitalWrite(servoPin8, HIGH);
    delayMicroseconds(pulsef);
    digitalWrite(servoPin8, LOW);
    lastPulse = millis();
so the problem is what if i wish to move both servos at the same time in sync? any ideas how shld i change the code?
First thing, look at using one of the servo libraries - it means you don’t have to refresh the servos yourself, and makes your problem a whole lot simpler.
http://arduino.cc/en/Reference/Servo
http://www.arduino.cc/playground/Code/MegaServo
#include <MegaServo.h>
#define servoPin7 7
#define servoPin8 8
MegaServo servo7;
MegaServo servo8;
char id;
int angle=0;
int sigCount=0;
  servo7.attach (servoPin7);
  servo8.attach (servoPin8);
  readSignal();
    if (id=='e') {
      servo7.write( angle);
 if (id=='f')
   servo8.write (angle);
  if (id == 'g')
   servo7.write (angle);
void readSignal()
    if (sigCount==0)
      id=Serial.read();
      sigCount=1;
      Serial.flush();
      sigCount=0;
      Serial.flush();
Or thereabouts.
