How to take serial in on 0 & 1 and output on 2 other pins
Ok so I found the software serial functions so I can read/write to other pins. Now I am trying to figure out the best way to take the data from 0 & 1 and output (just pass it through) to my software serial pins (10&11).
I saw the wire library but wasn't sure if that was for just passing data between to arduinos.
I am just trying to test a connection between a remote and camera. I would like to make it wireless at some point but I want to see if the remote will work if I pass the data between the arduino.
BTW I tried a wireless rs422 (snap link) and it did not work so I am trying to figure out why. I have a feeling the remote needs to see a voltage before it starts transmitting.
Have you looked at the SoftwareSerial examples ? One of them does exactly what you describe. Reduced to the bare minimum it is.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11);
  Serial.begin(57600);
  mySerial.begin(4800);
  if (Serial.available())
    mySerial.write(Serial.read());
UKHeliBob:
Yes that's what I was using as my code, just thought I might have it wrong since the controller does not work. Thanks
