how to take values of temp sensor in byte array and send it using bluetooth
Hi everyone,
Could anyone please tell me how to take temp values in Arduino and sent it using Bluetooth.
Because while sensing through Bluetooth the data got stucked.
So i want to read analog values from analog pin and store them into byte array and then want to send that byte array through bluetooth
rjrajbir:
Incoherent.
Can you store the data in byte array and the send it to the serial monitor?
I assume that you realise that analogRead() returns an int, each of which takes 2 bytes of memory. Why not store then in an array of ints ?
