How to talk from one HC-SR04 ultrasonic sensor to another?
I would like to send a signal from one HC-SR04 and receive it on a second HC-SR04. I tried to write this program but it always prints 0 cm. The code is the same as we would use for an echo ping. The only difference is that I trigger the trigger pin on the first HC-SR04 and listen on the echo pin on the second HC-SR04.
I think that this might be the problem:
RiGonz:
... it seems to me that the receiver needs the activation done by the emitter sending the ping, on the same module: ...
Can anyone help?
There was a suitcase tracking thing, where the first micro triggered its ultrasonic to send, AND using xbee or something, wirelessly triggered the other end to listen.
But I wonder if this is an XY Problem?
Can anyone else see this program?
AWOL:
const int trigPin = 2;
const int echoPin = 4;
pinMode(trigPin, OUTPUT); //triger pin on sensor 1
pinMode(echoPin, INPUT); //echo pin on sensor two
// establish variables for duration of the ping,
// and the distance result in centimeters:
long duration, cm;
// Sensor 1 is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor 1 on sensor 2 (a HIGH pulse)
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
cm = microsecondsToCentimeters(duration);
Serial.print(cm); //PROBLEM THIS IS ALWAYS 0
Serial.print("cm");
delay(100);
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
return microseconds / 29;
The HC-SR04 has a built in microprocessor and cannot be used in the way you are attempting.
jremington:
do you think desoldering might be an option to achieve what i am after? If not is there something you could recommend as an alternative to HC-SR04 ?
Here a link who explain how works "one" of the different HC-SR04
http://uglyduck.ath.cx/ep/archive/2014/01/Making_a_better_HC_SR04_Echo_Locator.html
Article is dated january 14. I buy some units on Ebay (1$/€ per unit) Feb 2015 there is always the same "cut and paste" : filter is always centered to 20 kHz.
I have not succeeded to discover the micro program, I do not know what he does.
Micro does not directly manage the length of the burst. The burst is not controlled by timers but by powering on/off the Max232.
This can not work properly: the charge pumps that generates the + 10V and -10V can not be activate in a such short "ON" time.
I checked with an oscilloscope: the output level of the Max232 is effectively only 0 / + 5V -> it is useless.
If we add the loss of gain due of the filter mis-centered at 20kHz and the output level of 0 / + 5V instead of -10V/-10V, total loss of gain is about 40 20 dB , in pure number attenuation of 100 10 !
The amplifier used has an average Ft of only 700kHz . With a gain of 10, bandwidth will be only 70 kHz. Do not forget that the bandwidth is defined as the frequency which corresponds to a gain divided by 2!
With 4 cascaded amplifiers, bandwidth of the whole chain is less than 40 kHz !
As the LM324 is not rail-to-rail, last stage of LM324 associated with transistor Q1 is used to make a pseudo open collector comparator.
The schematic is very unstable and enter too easily into self-oscillation .
Nevertheless, we must recognize that this module works. But change nothing, otherwise nothing will work.
If doing some electronics do not put you off, you would have interest to make a board with an atmega328 (like nano or mini-pro), amplifiers with 3 Mhz Ft like TL082N (10 for few $/€ on Ebay) and use a real comparator (like LM393) to interface with the micro.
US microphone can be directly controlled with an ATmega328P.
Here a link to do a burst à 40 38 kHz:
Modulating a 38 kHz carrier with a 500 Hz signal
