How to talk to a serial device with certain requirements
Hi there
i want to create a ardunio device that communications to a Serial Device. It would send a command and then wait for a reply and send another, etc.
But the serial Device uses a certain type of class to encode the command before sending. It uses a CRC16. which i use in my C# program in Visual studio. i have attached it.
i’m not very good with the arduino but still learning.
How would i go about doing this?
Thanks
regards
jeremy
crc16.txt (2.38 KB)
i have attached it.
It seems not to be attached
Does it actually encode the data or just send a CRC value with it ?
you should see it now. when i first posted it. the site wouldn't let me attach the file.
to send a command i just send this to the serial port Crc16.GetCommand("QOPM")
Depending how the port is set up the device replies in hex. and then do a Encoding.ASCII.GetString()
if you would like to see what i use in my C# project i can show you my data send and receive.
I don't know why but this site keeps coming up with "
You have exceeded the number of posts you can make in a 5 minutes period. Please try again later." start to get very annoying.
The 5 minutes between messages for low count posters is an anti spam measure. The forum software does that when you only have a few previous posts and it will stop doing it after the trigger level has been reached.
There are CRC16 libraries for the Arduino such as GitHub - vinmenn/Crc16: A simple crc-16 library for Arduino but I have no experience of them.
A search for CRC16 in the forum could also be useful
